27
274
Originally Posted by
cv2065
Fitted the Breeze rollbar. Man, you gotta love this thing. The height, rake and thickness is perfecto! And NO frankenstine bolt.
Time to cut the holes. I had to enlarge about 1/4" on each hole for the Breeze bars. My hole cutting friend at FFR struck again and each hole was about 1/4" off moving outboard. I've got to buy this guy some lunch just on consistency alone!!
Draped the plastic tarp over the car to keep it clean and cut the plastic out around the holes and taped it down. My wife came in while I was going to work with the Dremel and said I looked like a surgeon with my respirator on. Yes!!
Once done, I misjudged the rear leg a bit as I forgot Jeff Kleiner's advice about notching the back leg so that the hole doesn't have to be so big.
I searched the forum but no luck. Can you say more about this or maybe Jeff can weigh in? I have to start this soon and I want to get it right.
Thanks@!
Dan
