I searched the forum but no luck. Can you say more about this or maybe Jeff can weigh in? I have to start this soon and I want to get it right.
Thanks@!
Dan
When you fit the back leg, you'll see what I'm talking about. The rear lip of the third leg won't clear unless you expand the hole a bit more rearward. Jeff suggested cutting a 'V' shaped notch in the bottom part of the leg to clear the body a little better so the hole doesn't have to be so large. Once you get the trim rings on you can't tell one from the other but if you go just slightly too large, the stock trim rings might not cover the gap completely.
