Thanks Thanks:  45
Likes Likes:  120
Results 1 to 40 of 241
Thread: Dan's 818C (Lightweight818)
Threaded View
  1. #10
    Jun 2020
    Danville CA
    For the belt routing, I was referring to how the webbing is threaded through the hardware.
    I raised my engine by 1/2". I just put a 1/2" piece of steel stock as a spacer between the mounts and engine block and got longer bolts. I couldn't go any higher otherwise the turbo flange would hit the bolt on cross member. But that might not be a problem if you are using an OEM turbo.
  2. Thanks BigDanSubaru thanked for this post
    Likes BigDanSubaru liked this post
