257
397
Originally Posted by
Erik W. Treves
so do yourself a favor- make sure when you are checking the lights - you have all 4 corners hooked up!
I have had 2 IDIDIT columns have shorts in them - and found them during final assy.... would be much easier to resolve now.
Also in the rear you want to verify that the turn signals and hazards stay engaged (in the rear) when the brake is depressed... I believe you have to remove 1 wire from the connector (pin P) if they don't work correctly
Thanks Erik. In the process right now of hooking up the rear lights to test more thoroughly. I very quickly put one on this AM before doing the wiring addition to the rear lights shown in the instructions. I did notice the hazards stopped flashing when the brake lights were engaged. Didn't test with turn signals. Will check further into the wiring fix.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
