so do yourself a favor- make sure when you are checking the lights - you have all 4 corners hooked up!
I have had 2 IDIDIT columns have shorts in them - and found them during final assy.... would be much easier to resolve now.
Also in the rear you want to verify that the turn signals and hazards stay engaged (in the rear) when the brake is depressed... I believe you have to remove 1 wire from the connector (pin P) if they don't work correctly
