Quote Originally Posted by Pat Landymore View Post
What about parking lights off, key off so there are no DRL’s showing, and then turn the 4 ways on? I believe you will have “4 ways” flashing out back, but nothing showing up front until either key or park is turned on.
That is the situation I used the diodes to rectify…and would be a common issue if one was broken down at the side of the road…all you would likely want is 4 ways. ??
Thanks. But I mentioned that near the end of my post. Just not in the video. If I push the hazard button with nothing else on, still works properly. The testing in my post was without the rear lights wired. I'm going to clip in the rear lights and test further. But a quick check this morning with one clipped on and everything still works. Including the brake lights without the brake light wire attached per the instructions. Interesting.
