Folks,
Appreciate the feedback so far. Looks like I got a lot to learn here.
1. Pigtails/Curly Q's: I was advised to do this by the build school and I've done similar before w/o issue so I didn't think badly of it. I agree if they can be avoided, it would just be one way to reduce frustration and possibility of trapping air. I'll look into minimizing these, especially the multiple loops.
2. I verified there are no pedal interferences. I think my pics aren't quite as clear so it's hard to tell. None of my pedals get close to the firewall. However, I'll see if there are other routings that avoid this region altogether. If all else fails, I'll exit the firewall and go around the outside of the footbox. Cross my fingers on the heat.
3. Any issues with how I went down the 3/4" tube near where the fuse panel usually is mounted? I think it's okay b/c my line is on top of the tube and the fuse panel mounts to the bottom. I could move the panel to the pass-side if needed but would prefer to place it on the driver-side.
4. Anyone have a part number/brand/model for the thread sealer? I've never used this on threaded brake pipe fittings without any issues so I'm leery of doing it here. However, I respect your advice.
Thanks again,
Jay
PS. I have no idea how the thumbnail of the sunset got in there but hope you enjoyed it. I also have no idea how to remove it.
______________________
Current project: Mk4 build started September 2025
OB6 liked this post
