Looks pretty good. You will want to use hydraulic line sealer on the brake lines so they don't leak. I know several people use Teflon tape which will degrade in the brake fluid. Good on you for using those brake lines. I couldn't get them to bend or flare for the life of me. I went with copper and made custom length lines.
Definitely bench bleed the master cylinders and start out by gravity bleeding like the manual suggests. Good luck!
