Thanks Thanks:  40
Likes Likes:  124
Results 1 to 40 of 471
Thread: Tim's Type 65 Build - Cockpit Wiring Finished?
Threaded View
  1. #11
    Nov 2020
    Damascus OR USA
    I have decided to try the Fluidyne expansion tank. It has three inlet/outlets which I believe will work for the Coyote setup. The outlet at the bottom will be the return to the heater fitting at the front of the engine, the other large outlet will be the incoming line from coolant return. I need to determine connections i.e. do I use Ford connectors on the engine side and AN on the tank side or something else?
    Here are a few pictures of the tank and where I plan to mount it. I was a bit surprised by it's high polish finish as I guess I missed that in the description.
    I will need to fashion a bracket to drop the tank about 2" but that should be pretty straight forward. Although I know the return line/overflow from the radiator is in the neck of the tank it does discharge directly into it so I am thinking this is OK. If anyone thinks this setup won't work please let me know.
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
