40
124
PNWTim
I feel like I am at the stage of my build where it seems nothing is moving forward but I am spending a significant amount of time in the shop. I suppose small items are just as critical as large, they just don't feel quite as impactful. I have continued on my path to install the computer in the dash area. I fabricated some spacers to raise the mounting points of the ECM so it doesn't interfere with the upper footbox sheetmetal:
I then cut a hole in my firewall for the computer and mounted it by through-bolting it through the cross frame member on one side and tapping the other with a 1/4-28 thread. I had to tap the inboard bolt as I inadvertently placed this hole over a frame junction and weld. It feels very secure even though it is cantilevered out quite a bit.
Boy, can I relate to that. It's the tradeoff I suppose for going off script.
That's a clever spot for your PCM. I don't think I've seen that location used before. Definitely tucks it out of the way, minimizing visibility.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
