Thanks Thanks:  40
Likes Likes:  124
Results 1 to 40 of 471
Thread: Tim's Type 65 Build - Cockpit Wiring Finished?
Threaded View
  1. #11
    Nov 2020
    Damascus OR USA
    Quote Originally Posted by wedel456 View Post
    Have you thought through your firewall extension panels as it relates to the position of your wiper motor? I think you are going to have some interference with your placement.
    So, the short answer is no. I sat there and stared at that spot wondering if there was going to be any interference from anything and decided it was going to be OK. I had totally forgotten about those panels which I believe are at the powder coaters at the moment. I appreciate the heads up though. I have room to move it so no real harm done.
    EDIT: I just looked at the build manual and you are absolutely correct. Looks like I need to move it about 2" inboard (hard to tell from the photos) to clear the sheet metal. At least it will cover two of the four holes...
    Build 1 - 1969 Camaro Build Thread Here: https://www.camaros.net/threads/tims...y-getter.45926
    Build 2 - 1965 Daytona Coupe # 620 Build Thread Here: https://thefactoryfiveforum.com/show...-Type-65-Build
