27
274
Studs and Remflex gaskets, can't get better than this especially with the 3" spread mounting for the headers.
FWIW the only thing "lock washers" are really good for is taking your money. If you break down the physics of a bolted connection and the forces involved you can easily see why these things contribute nothing and in some cases are actually detrimental to the joint. Stick with the ARP hardware as designed.
