50
156
So I started the install and had some hiccups. The body is still on because I have a guy coming to look at it and give me an estimate.
Step 1. Install the PS rack. Went ok but I had to grind the bracket that holds it on because it was too tall and was flexing one of the lines.
Step 2. Install front LCAs. Went ok but the sleeve was 1/16” wider than the bushings so could not get the washers/spacers in. After a few minutes of grinding was able to get them in, greased with silicone lubricant and torqued down. Could only do the left side as I found out I’m missing the sleeves for the right side. There was no inventory for this, so no way to know. I added to the missing parts list.
Step 3. Upper CAs. Here I’m stuck. Need some help. It calls for .84” spacers… but I only got .675, .4, and .5! I checked the entire inventory, 40+ sheets, and there is no 60766 spacer! Anyone run into this? I guess I will call them tomorrow.
Step 4 will go better!!!
Build School: 5/2/2025
Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
YouTube Channel
