50
156
Some detail on the gas pedal install. There is a hole in the frame cross member to accept the steering bearing and next to it is a hole for the cable.
As far as attaching the pedal, there are two holes in the welded bracket in the foot box. When I used the second hole from the bottom to attach the bottom hole of the pedal bracket the top of the assembly lined up with the cable hole, so I decided the hole must be a guide to align the pedal. I then made the pedal parallel, as best I could, to the brake and marked and drilled the top hole. This kit seems to be infinitely adjustable which is good for some but scary when you get paralysis by analysis.
Hopefully this helps.
Build School: 5/2/2025
Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
YouTube Channel
