50
156
I am behind where you are on my MK V build but I thought I would post here as a possible help to other builders with Sasquatch feet. I moved the throttle pedal up about 2" and moved it as far to the right as possible. Otherwise when I went for the brake in a hurry I might also be on the gas. Powerbraking can be fun but not in that instance. I had to bend the upper are of the pedal assembly so it would not hit the steering column.
