M22_COBRA
Question: I am running the ford control pack for the gen 3 coyote, no AC, no heat, no radio... I'm gonna have 4 wheels and a seat, you get the point.
Per the instructions, the Ford control pack runs the fan via the orange wire (I think this is already #10?) directly to the fan power to control the fan (correct?). Do I still need the relay changed? Thought I read somewhere that the RF / Ford PCB are sized properly if I'm not running other accessories? Appreciate the clarification.
Assuming you want the Ford Performance control pack to control the cooling fan (my recommendation) the orange wire from the control pack goes directly to the plus side of the cooling fan. Ground the other side and you're done. The RF fan circuit isn't used at all. The RF fan circuit does however become a relay controlled circuit that you can use for something else. If you want. The one downside though is it's a battery circuit, meaning it's powered all the time regardless of the ignition switch position. That can be dealt with too if necessary.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
