G'day Brad,
Looks like you are well under control with a seat belt solution, but I thought i would just pass on my Roadster solution:
Retractable seat belts are required by law in South Australia. However, on the roadster, the seat belt shoulder strap is too low when installed in the conventional position, to meet the requirements. The workaround is to fit the shoulder strap in the centre of the car, where the body curvature is highest, per the pic below. Not the best photos, however you can see the red seat belt release button alongside the drivers seat. The retractors are mounted in the trunk.
Surprisingly you get used to it quickly, just like the reverse speedometer.
Thanks for all the detail you have put into documenting your build. It has been great to follow along. I work with industrial inverters / battery systems. It is great to see a fun application like a hot rod. So much more exciting than a boring UPS.
Best of luck with your firmware issues.
Nige
