progmgr1
I've got seat belts on the list of issues to consider when (if) I finally get to go-cart. Past forum research led to the following posts from other builders:
I got the three-point retractable belts with aircraft buckles from Wesco (
http://www.wescoperformance.com/). I fabricated mounts out of some thick steel I had lying around.
I bought a set from Seatbeltsplus.com 3 Point Retractable Seat Belt, End Release Button, 22" Cable
Make sure you get the 22" cable so that it is long enough. I mounted the retractor to the outer FF5 floor brackets and the cable to the inner FF5 floor brackets. I fabricated brackets to slip around the roll bar to attach the shoulder harness. I used 1" ID O-rings above and below the brackets to keep them in position. The cable with the latch must run inside
http://www.ffcars.com/forums/attachm...hotrod-93-.jpg
http://www.ffcars.com/forums/attachm...hotrod-90-.jpg
Alternative 4 belt seatbelt with retractor:
http://corbeau.com/other/harness-bel...ness-belt.html $109.
I have Schroth's Profi II ASM FE a four point system with their proprietary system (they call it ASM) to prevent submarining with just four belts. Recommended to prevent crushing intestines in crash.
The Schroth system sounds particularly interesting since most builders dislike the 5th belt, and having retractors on a 4 belt system is much more user friendly than the stock FFR system, IMHO.
I hope the above gives you some useful alternatives to consider.
Keith HR #894
I just got the 3 point harness that FFR uses on the truck. They fit fine and include the upper attach bracket that mounts to the Roll Bar.
- Peterh226
35 Hot Rod Truck (Ext) Delivered 11/21/24
33 Hot Rod Gen 2 #1134 ~1400 miles
54 Pontiac Star Chief
05 F-150
