Thanks Thanks:  54
Likes Likes:  130
Results 1 to 40 of 487
Thread: Danny Boy's Mk4 Build - Putting the project on hold for a while...
Threaded View
  1. #11
    Sep 2011
    Minneapolis, MN
    Wow, you're having lots of fun, from cockpit layout to wiring. Good for you. I know now how you got attached to your new location for the emergency brake .
    One question about your wiring, since you labeled it in a photo ... do you need that gauge wire going to the ECU (are its power requirements that high)? Related question: is the mega-fuse in this location protecting anything, practically speaking?
    I'm no expert and I haven't been wiring up a Coyote, so I could well be missing something. Including, obviously, the power requirements for the ECU. Wait for others to chime in, which they will if I'm off base.
