54
130
Originally Posted by
Fman
Does the T-56 have a rubber doughnut to remove? On the TKO600 you can take a pair of needle nose pliers and it pulls out which made it much easier for me to install my driveshaft. It is a tight fit, I would be surprised if you could install the drive shaft with the Metco hoop installed. I had to drop my transmission as far downward possible to create enough space/correct angle for the splines to align and push into the transmission.
There IS a black rubber seal looking thing at the tail of the transmission:
However it really doesn't look like it should be removed. I can also slide the drive shaft in just fine with it in place:
