Thanks Thanks:  84
Likes Likes:  481
Page 1 of 18 12311 ... LastLast
Results 1 to 40 of 685
Thread: 25th MKIV #9772 Build NOR*CAL: new vanity plate
    Folsom, CA
    Attended Build School with my son August 2019
    Ordered a 25th Anniversary MKIV October 25th, 2019 - pushed finalization to January 18, 2020 to finalize funds
    Car was finalized for pickup, #9772 which is #20 of 25 of the 25th Anniversary Cars.
    Stewart Transportation was selected for delivery, $2,100 from Boston to Sacramento Area.
    Picked up on 1/22/19, and delivered 2/6/20 (some weather delays) and I was car #10 in a trailer full of 10 cars... ours was tucked WAY in the back.
    I turn 50 this year, 25 year anniversary at my workplace, and 25th anniversary for Factory Five - the planets have aligned!
    My son (23) and I will be the primary workers on this car, we've done several things with cars from brakes, to axle replacements, to simple stuff like stereos, wheels, etc. But this is a whole new ballgame!
    I've created a website to capture all the thought, progress, ideas for this endeavor: https://cobradreams.com
    I've made my color choice - here is the color!!!
    25th Anniversary Kit Details: Original PO for Build
    Part# Description
    50013 MK IV COMPLETE KIT
    16800 25th ANNIVERSARY KIT COMPONENTS
    - Bronze Chassis
    - Satin black aluminum footbox panels
    - Anniversary GPS Gauges
    - Anniversary Wilwood brakes
    - Exclusive bronze 18" wheels
    - Anniversary leather seats
    - Anniversary badges
    - IRS w/front & rear sway bars
    - KONI double-adjustable shocks
    - Assembled louvers
    - Chrome driver's rollbar w/grommets
    - Stainless steel exhaust & bumper kit
    - Carbon fiber dash
    - Sun visors & Wind wings
    - All new body mold
    15440 Modular 4.6/Coyote Engine/Transmission Mount Kit
    16972 Coyote Full Length Headers w/Cats w/Kit
    60175 31 Spline 2015 IRS 10.50" Driveshaft
    12066 Front Lower Arms - Standard Width
    15549 Roadster Wiper Kit
    12469 Brake Duct Wire Mesh
    15015 1.50" Passenger Side Chrome Roll bar
    15158 1.50" Roll Bar Grommet Set
    16863 GEN 3 COYOTE INSTALLATION KIT
    DISCOUNT 25th Anniversary Discount
    DEPOSIT Deposit $2500 C/C 10/25/19
    DISCOUNT BUILD SCHOOL DISCOUNT
    Engine & Transmission Plans: Forte's Coyote Engine Package
    M-6017-M50B GEN III COYOTE ECU
    M-8600-M50BALT ALT KIT
    GEN III COYOTE ENGINE COVER KIT
    Tremec TKX TCET17765 FORD TKX 2.87 / .68
    QT RM-6080 4.6 COY TKX
    FORK COY CLUTCH FORK W/ PIVOT
    T/O B 614014 FORD LATE USA TIMKEN
    BOLT KIT & FLYWHEEL, CLUTCH BOLTS & PILOT
    ACT COY 164T COYOTE FLYWHEEL 8 BOLT
    M-7560-T46 11" 26 SPL 4.6 CENTERFORCE
    MINI COYOTE MINI STARTER N/C
    COYOTE OIL FILTER NIPPLE
    OPTIONAL OPTIONAL PARTS & LABOR BELOW
    MOR COY GEN III PAN & PICKUP WITH GASKETS & BOLTS
    EXT HYD EXT HYD KIT MK IV MINUS MASTER
    LABOR-A ASSEMBLE TO TURNKEY & CRATE
    COY AIR K&N FILTER AIR INLET KIT
    ENGINE ENGINE LIFT PLATE COY REFUNDABLE $95.00
    + FREIGHT costs
    Tires:
    Yokohama ADVAN A502
    315/30R18
    265/35R18
    Body and Paint: Ken Pike will be the man!
    Here are the aftermarket items I have already purchased
    Metco Driveshaft Safety Loop
    Boyd Welding Factory Five MK4 25 gallon fuel Tank
    Aeromotive Stealth 340 Fuel Pump
    Aeromotive 12347 Line Filter (an-6 Male) 10 Micron
    Aeromotive Fuel Pressure Regulator with 100PSI gauge
    DWC rearview mirror mount
    DWC door sill trim
    Forte's Parts Ford Super 8.8 3.55 Differential W/ Knuckles & Hubs
    Russ Thompson turn-signal
    520 Speedwork hidden-rollbar mounts
    Breeze Black, 5-Speed Pattern with Cobra(R) Snake Logo Both Sides
    Breeze Hose and Fitting Group for FFR 16137 Coyote Power Steering Kit
    Breeze Engine Compartment Battery Mounting Kit, MkIV Roadster
    Breeze Dead Pedal Kit for use with Wilwood Pedal Box
    Breeze Radiator Fan Shroud
    Breeze Offset Rack Mounting Kit for FFR Roadster
    Breeze Heavy Duty Hinged Radiator/Shroud Mounting Kit
    Breeze Lower Radiator Support Kit
    Breeze Radiator Cowl Cover Kit for use with FFR Hinges
    Breeze Steel Frame Seat Mounts
    Factory Five 16461 Coyote KRC Power Steering Kit
    Factory Five Gen3 A/C + Heater Kit
    ididit 3100006040 relays for Russ's turn signal button
    Replica Parts Radiator Panel
    Replica Parts Brake Booster Spacer
    Replica Parts Rear Quick Jack Plates
    Replica Parts Seat Belt Trim Plates
    Replica Parts Under Dash Filler Panel
    Replica Parts Windshield Post Trim Plates
    Replica Parts Russ Thompson Turn Signal Bezel
    Wilwood Electric Parking Brake Kit
    Drummer Mike polished Heat Shields
    Fortes A/C Pedal Extensions
    GT500 ABS Custom Setup
    Plans to buy:
    MKIV Wheel Well Liner Kit
    Todd
  2. Likes ydousurf, Drezx6r, 2FAST4U liked this post
    Feb 2019
    Greality, Colorado
    Toadster, looks like you have a very thorough and complete plan in place and your ready to build! I've been out on your site too, nicely done! I'm in front of you with #19, but I'll surely be behind you in my build (planning a few years to complete mine) and will be following yours closely. I dig the color scheme and it should look sweet once it's completed. Enjoy the build and more importantly, enjoy building it with your son and other family members and friends too!
    Dj
  4. Thanks toadster thanked for this post
    Likes toadster liked this post
  5. #3
    Congratulations on your anniversary roadster. I look forward to watching it go together. I’ve never seen the Boyd’s tank in a roadster. The ones they build for the 33 are nice. I’m sure you and your son will have a great time.
  6. Likes toadster liked this post
  7. #4
    Folsom, CA
    first pass on inventory is complete!
    https://cobradreams.com/2020/02/12/f...nventory-done/
    next pass will be verifying all part#s that are missing and aligning with POL
    Todd
  8. #5
    FFR Maven
    Huntsville, AL
    Congrats!! Looks like a solid build plan.
    The FFR wipers work, but many have reported that they’re not the highest quality (especially for the price). A solid alternative was found by EdwardB, which is a kit from Specialty Power Windows (model WWK-2). Similar style setup but all the parts are beefed up compared to the FFR/Lucas ones. And it’s also around $300 instead of $500. Just letting you know there are options.
    Good luck with the build! The stars have indeed aligned.
    Logan's Gen 3 Coupe-R Build
  9. Thanks toadster thanked for this post
    Likes toadster, bill1982 liked this post
  10. #6
    Folsom, CA
    Quote Originally Posted by Logan View Post
    thx for the update, I've tried to gather a LOT of pre-purchase info... wipers I'm not super worried about for functionality - hopefully won't see too much rain around here
    Todd
  11. #7
    Folsom, CA
    Cool
    here's my POL update
    and the missing parts list, surprised the shocks were missing!
    Todd
  12. #8
    Folsom, CA
    assembled the Wilwood hats & rotors with safety wire...
    Todd
  13. Likes ydousurf, Fman liked this post
  14. #9
    Jan 2020
    State of Jefferson
    Way to go Toad! off and running... I am following your build progress, hoping to learn something. If you ever need another body to help please let me know, more than willing to come over and help.
  15. Thanks toadster thanked for this post
  16. #10
    Bakersfield, Ca.
    Congrats on the build! Just couple things on the Gen 3 Coyote...make sure it's plumbed with the OEM and the Seed Hut Oil Pressure senders and be prepared to trim the engine cover considerably (especially if you plan on using the gas struts!)
  17. Likes toadster liked this post
  18. #11
    Folsom, CA
    Quote Originally Posted by rodneyarcher1 View Post
    ahhh I love autocorrect! I'm sure you mean Speedhut Oil Pressure Senders
    yes, I've been watching Paul's build on his coupe...
    https://thefactoryfiveforum.com/show...l=1#post398469
    I need to put sticky notes in my manual!
    Todd
  19. #12
    Folsom, CA
    A little more scrubbing on the diff today...
    A little iron-x LOL DANG
    NICE!
    Tomorrow gets clearcoat
    Todd
  20. Likes Mark Eaton liked this post
  21. #13
    Folsom, CA
    Talking
    lots of work yesterday!
    I went a little backwards, normally I'd do the POR15 THEN the shiny parts, but oh well - the aluminum cover was shined up and clear-coated
    Even after a day of using the ironX spray, I had more surface rust to hit...
    the Dremel with a wire wheel works very well!
    I used some scotch brite pads to ensure the dust was knocked off, used my air compressor to blow off any extra materials then started the degrease process for the POR15 kit, this little kit was PLENTY for the IRS diff...
    POR-15 40909 Gloss Black Stop Rust Kit - Permanent Corrosion Preventive System $21
    Here's a quick video showing the metal prep step of the POR15 process, very important to have the POR15 coating stick!
    The IRS diff is VERY heavy ~ 93lbs. and awkward to move, I have to give @edwardb credit for building a mount for his setup - I used a milk crate and it's a real PITA to setup properly due to the design
    once the prep dried (quickly thanks to compressed air) I was ready for the stinky stuff! Don't' worry that it's such a tiny amount, it's self levelling and works VERY well!
    The end-result was awesome! It's funny how many of us enjoy doing this to a part that most people will NEVER see!
    While the diff was drying, I finally got to removing the doors, trunk, hood, the front/rear bumper mounts, front body mounts, and the 4 body screws under the doors.
    Todd
  22. #14
    Folsom, CA
    I had a few helpers...
    next I marked the inner body panels that will be trimmed to fit later once the body is off... this was recommended at the build school, run a sharpie perpendicular to the body and trim along that line.
    I noticed that the front body mounts were bare metal, and many say they won't use them - but I figured if I do, I painted them (not really seen but now protected)
    I bagged and tagged the parts removed to make sure they don't get lost, and also not mix the front and rear bumper mounts - they look similar but very different!
    and the final shot of the body, ready to pull and mount on the buck tonight (hopefully!)
    Todd
  23. #15
    I suggest that you revisit this because there is no way you'll need to remove that much material.
  24. Thanks toadster thanked for this post
  25. #16
    David aka Ducky2009
    Lilburn, GA
    You might want to revisit your lockwire spec. The lockwire should be tight enough to NOT allow a bolt to rotate. The bolt to the left could turn/loosen because the wire "between" the bolts is too losses.
    Good luck in your build! Never stop asking questions. There is a wealth of information here.
  26. Thanks toadster thanked for this post
  27. #17
    Folsom, CA
    yes, I agree I have a few to re-do, just need to get more wire... surprisingly, the 27 ft of wire that came with my safety pliers was a perfect amount for what I used...
    agreed, the sharpie I used had a pretty fat tip on it, so most likely will trip to the TOP of that line (not the bottom)
    Todd
  28. #18
    ...so most likely will trip to the TOP of that line (not the bottom)...
    Personally I'd recommend not cutting anything until later in the build. I know they say this at build school. All due respect, they've been saying it for a long time and I'm not sure the fit is the same as it used to be. Sheet metal and body are placed for shipping. Not way off necessarily, but also not necessarily where it all will be later when finalized. As the saying goes, you can always remove material. But hard to put it back once it's off. I've never had to trim that much (either side of your lines...) in three Roadster builds. You'll find it's just not hard to take the body on and off. Even a few times.
  29. #19
    Folsom, CA
    point taken! thanks all
    Todd
  30. #20
    Folsom, CA
    With the help of my son and one of my friends, we were able to successfully re-assemble the body buck, pull the body, and strip the panels to get to the base frame!
    first we assembled, and tested to make sure it fits in the garage - yay!
    body removed and resting on the buck!
    from my previous 'upgrade' I added some locking casters, the bummer is that they're about 1.5" taller than the old ones, so we had to remove the front ones to clear the garage door!
    next we tagged and pulled the interior panels (many of which are on the POL)
    believe it or not, the rivet spacer is on POL, I mean really?! So my son was creative and took one of his old rulers from elementary school and modified it
    the F-panels were in a separate box for the engine bay panels, so we drilled and cleco'ed them in until I get a new tube of silicone
    Todd
  31. #21
    Folsom, CA
    Mounting the front LCAs - the passenger side was just like the manual - one spacer in the rear mount, the front was perfect
    The driver side was a PITA, front mount needed coaxing with a dead blow hammer, the rear has 1 spacer but looks like it needs a 2nd - should I put a second one?
    Passenger side:
    Driver side
    Todd
  32. #22
    Bakersfield, CA
    I’m right there with you Toadster! Pictures from Sunday. 7/31/18 delivery
    Build thread
  33. Thanks toadster thanked for this post
  34. #23
    Feb 2019
    Greality, Colorado
    Hey Toad, I would follow what the FFR Manual on how it advises for assembly and/or consult with the tech folks at FFR. With that said, I'm actually wondering why there are not spacers on each side for both upper and lowers and perhaps even copper (wearable) spacers on each side? Yes, they wear out, I know, that's the point! None-the-less, are you greasing them up prior to install? I also did notice that the upper plastic/rubber spacers have "grease grooves or slots" manufactured in them. They're similar to the modification that many have made prior to them manufacturing them this way, which is great, since I was planning to mod them. I'm thinking there should be something not similar, but a small mod on the lower part to allow for better grease coverage to flow. I have a couple ideas I'm thinking about. I'm not at this stage yet, but I do plan to pre-grease all fittings as I assemble any friction/moving related parts. Anyway, you're moving right along, keep at it!
    Dj
  35. Likes toadster liked this post
  36. #24
    Quote Originally Posted by ydousurf View Post
    ...perhaps even copper (wearable) spacers on each side? Yes, they wear out, I know, that's the point!
    Dj
    Huh? There better not be anything moving on the LCA washers. The sleeves inside the polyurethane bushings get captured between the chassis tabs and are stationary.
  37. Thanks ydousurf thanked for this post
  38. #25
    Feb 2019
    Greality, Colorado
    Ahhh... I was thinking that the boxed bracket welded to the frame would begin to get wear over time and so the "sacrifice" would be on the spacers instead? Your explanation clears that up and so I'll not be making any mods to the sleeves themselves. Do we need to slot the poly parts like they are now done on the UCA's for better grease coverage? Thanks for clarification, Jeff!
    Dj
  39. #26
    Folsom, CA
    Total transparency... LOL I got my 15/16th wrench today, did the passenger side, and went to the drivers side... forgot to use the open ended side - whoops!
    Todd
  40. Likes WIS89 liked this post
  41. #27
    Darn, now you're going to have to buy a plasma cutter to get it out of there.
  42. Likes SSNK4US liked this post
  43. #28
    Folsom, CA
    Ugh seriously how do I get it out?
    Todd
  44. #29
    FFR Maven
    Huntsville, AL
    Least invasive: use another wrench and put the open-end on the nut, just inside of the stuck wrench. Remove the bolt.
    More invasive: cut the stuck box end ratcheting wrench out with a dremel. One of those rare cases where a non-reversible ratcheting wrench stinks.
    If it makes you feel any better, just the other day I installed a rivnut using my fancy tool in a tight spot, then couldn’t get the tool out of the newly set rivnut. I had to cut the threaded tip off my tool to get it out. This was after I wasted an hour+ trying to get it out. Tried disassembling the tool and everything, but it was not possible. To replace that one tip I need to buy the whole set of tips for $35. Ouch. Least I learned something...
  45. Likes Mark Eaton, WIS89, Derald Rice, toadster liked this post
  46. #30
    Please step away from the tool box, turn off the light and leave the garage.
  47. Likes M. Townsend, WIS89, toadster liked this post
  48. #31
    Folsom, CA
    well, i guess i'm off to buy another 15/16ths wrench to see if step #1 works.
    yeah, my excitement got the best of me, last of 4 bolts mounting the LCAs - the first 'parts' on the car... thinking the clearance was like in front of the tube, but not so... I did leave the garage, today is a new day
    Todd
  49. #32
    Bakersfield, CA
    Hate it when that happens lol Wrench might be to wide to fit. I’ve ground lots of wrenches thinner in my life over the years.
    I’d try some needle nosed visegrips first, it’s almost like grabbing the nut with a wrench.
    Good luck!
    Kurt
    Build thread
  50. #33
    Is everyone really that dense? You don't know what an open end wrench is?
  51. #34
    Bakersfield, CA
    He used a ratchet box end wrench and when the bolt came through the nut it trapped his wrench. When he tries to take out the bolt the ratchet spins freely and won’t loosen the nut. I don’t think he’ll be able to get another open end wrench in there, not enough room. We’re just trying to give him ideas how to get his wrench out. He wasn’t thinking the bolt would come through and trap his wrench. If it wasn’t a new fangled ratchet wrench he could just back out the bolt. He even said oops I used the wrong end. Any way you look at it his wrench is stuck and he’s looking for help. He made a mistake.... he’s not dense.
    Kurt
    Build thread
  52. Thanks Railroad, toadster, ydousurf thanked for this post
    Likes toadster, AgileYeti liked this post
  53. #35
  54. Likes toadster liked this post
  55. #36
    Bakersfield, CA
    Yeah like those... or a grinder and a cheap wrench lol
    Build thread
  56. Likes Railroad liked this post
  57. #37
    Feb 2019
    Greality, Colorado
    Hey Toadster, sh!t happens and we all make silly mistakes. Gotta love it when you assemble something and forget a part or whatever and have to redo it, it only equals frustration and curse words, but please, don't throw the wrenches! As said above and/or get a harbor freight or cheaper brand tool and grind one side down if necessary. I know I've made my share of mistakes and had to make some "custom tools" to get me out of that particular pickle, but I still use some of them when a wonky situation arises. Wrench on...
    Dj
  58. Likes SSNK4US, WIS89 liked this post
  59. #38
    South Australia
    You could just leave it there and tie it to the frame. A lifetime reminder of frustration and fun building these things.
    Only joking.
    Cheers, Nigel
  60. Thanks toadster thanked for this post
    Likes SSNK4US, toadster, M. Townsend, WIS89 liked this post
  61. #39
    Wedge a screwdriver under a flat on the nut.
  62. Likes Boydster, QKSLVR liked this post
  63. #40
    Feb 2020
    Worst case if the new 15/16 open ended wrench doesn't fit, use a grinder to make it thinner.... Also, bicycle wrenches are thin, might call your local bike shop and see if they have a 24mm in a thin bicycle wrench.
    https://www.amazon.com/dp/B003BBCKLC..._d0zwEbPDWB59M
    Ones like that, 15/16 is between a 23 and 24mm so it would be a little loose.
    Most bicycle shops will have that in stock.
