84
481
25th Anniversary #9772
Ducky2009
You might want to revisit your lockwire spec. The lockwire should be tight enough to NOT allow a bolt to rotate. The bolt to the left could turn/loosen because the wire "between" the bolts is too losses.
Good luck in your build! Never stop asking questions. There is a wealth of information here.
yes, I agree I have a few to re-do, just need to get more wire... surprisingly, the 27 ft of wire that came with my safety pliers was a perfect amount for what I used...
Jeff Kleiner
I suggest that you revisit this because there is no way you'll need to remove that much material.
agreed, the sharpie I used had a pretty fat tip on it, so most likely will trip to the TOP of that line (not the bottom)
