Jeff Kleiner
Did Blueprint install the Canton pan?
Yes Blueprint installed the oil pan as part of their Factory Five Engines package. One would think that this could and should be taken care of before being shipped out especially since they already fill it with oil to dyno the engine.
Ended up finding out also that their oil pan drain plugs are one use only due to them having a copper crush washer for the seal. I mentioned to them that I have a drop of oil leaking out the drain plug every several days of sitting.
