40
124
Originally Posted by
Namrups
Big milestone Tim! One issue you might want to look at is the placement of your remote battery hookups. I believe your upper radiator hose snakes thru this same area. Not room for both.
Scott
Thanks Scott and thanks for the heads up. I hadn't even thought about that. I bought the Boig's cool tubes so I guess I'll have to do a test fit. They don't hang below the angled tube so maybe there is still room? I can always move or delete them if needed.
