90
209
Originally Posted by
460.465USMC
Moving right along, Dave. Looking great! The nose interference issue with those side panels was not on my radar. I guess if I have an issue, I'll have some trimming to do. Though, my preference may be to trim the aluminum (like you did) instead of the nose.
Look good to me. This seems to be the thing to do. Will likely do the same when I tackle wiring in the near future. Thanks for the pictures.
I had the same experience. FWIW, I didn't put any rivets along the bottom diagonals in the rear corners. Didn't want to try to force it. I also didn't put any along the floor. I don't think F5 shows rivets in either place.
Thanks, Chris. I find myself winging it quite a bit with the panel positions. Ultimately, nobody will ever see where I put the rivets for the most part, as pretty much everything in the cockpit gets covered up anyway. I am trying to put the rivets in from the outside where they will be visible from under the car for the panel-to-panel attachments.
