09-18-2025, 10:17 AM
#561
I went out to do a few odds and ends on my build last night and found the battery to be dead again (3.3 volts, YIKES). I thought I had a bad unit (maybe I did) but I definitely don't have two. I did the troubleshooting and found that my problem was coming from the ignition circuit. When I test I have oscillating current from 48 to 72 milliamps. This is way to high. I connected my Digital Guard Dawg to the ignition wires on the RF harness with a high current weather pack so that made isolating it a lot easier. Sure enough when I disconnect it my draw drops to 9 milliamps. 8 of these are my parking brake.
So what to do. I have to live with it for now because I have to drive this thing to my pre scheduled appointments and I really need to drive it before the weather turns so I can shake it down. After I get it registered next week I think I am going to pull it and temporarily re install the key switch. The easiest thing to do will be to pre wire the switch to another weather pack and just plug it in for an easy conversion. I called DGD and they said I should never see more than 12 milliamps. They said to send it in and they will look at it. I have the key to push button and just to make sure the unit wasn't more "awake" because of the key, I moved both of them into the house. Still acts the same.
I did a search but only found one thread where anyone had this problem and it was never updated. Question, has anyone else seen this and has anyone just for fun measured their draw to see what is normal?
09-18-2025, 10:51 AM
#562
I had the same issue, installed a disconnect on the positive lead to isolate the battery. Problem solved for me.
09-18-2025, 11:19 AM
#563
Mike.Bray
I was thinking something similar.
Thanks Mike!
09-18-2025, 12:07 PM
#564
Ugh. Well good to know. I’m not in love with this thing and now I need to install another switch. Chuckle. Live and learn.
09-18-2025, 12:16 PM
#565
You guys are making your ignition way too complicated. Hah! Just use a darn key, and let insurance cover the rest.
Greg
Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
09-18-2025, 12:27 PM
#566
gbranham
you guys are making your ignition way too complicated. Hah! Just use a darn key, and let insurance cover the rest.
greg
k.i.s.s.!
09-18-2025, 12:29 PM
#567
I think my goal on this one was to make it as complicated as possible.
So far so good.
09-18-2025, 12:37 PM
#568
I installed my disconnect under the hood, my theory is I can lock the latches and add a level of anti-theft. Now if I can just find my keys to the latches....
09-18-2025, 12:42 PM
#569
Not a waxer
Mike.Bray
It’s OK Mike, if you can’t find the key to your hood locks you just need to find another Factory Five owner because every FFR hood and trunk lock is keyed the same! Every. Single. One.
09-18-2025, 01:28 PM
#570
Jeff Kleiner
You're weren't supposed to let that secret out! Now my plan is foiled
09-19-2025, 01:43 PM
#571
Blitzboy54
Hi Jesse. That's a bummer. FWIW, I did not have that issue with my DGD. I don't know what its amp draw was, but obviously, yours is too much. Also, I set mine to manual key mode, because I found my FOB to drain too quickly otherwise. Thankfully, there is an emergency bypass process, and it works (ask me how I know). I'm putting DGD in my Coupe build as well. Not so much for security, but mostly because I like the convenience of the FOB.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
09-19-2025, 01:52 PM
#572
460.465USMC
After reading this page, it sounds like using a key is the most convenient option so far...
09-19-2025, 01:53 PM
#573
I bought one of the knock off chinese versions on amazon and have never had an issue with it or parasitic draw and i use it with the passive entry fob. Only times i've had my battery go down are when its sat for at least 2months. I do keep a tender on it over the winter.
MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
09-19-2025, 02:02 PM
#574
JeffP
I bought one of the knock off chinese versions on amazon and have never had an issue with it or parasitic draw and i use it with the passive entry fob. Only times I've had my battery go down are when its sat for at least 2months. I do keep a tender on it over the winter.
2 months is about right, mine drops off a cliff somewhere between 6-8 weeks. IMO the car should be able to sit undriven for 60 days without an issue. I am going to put a push button inline switch to the 12v that feeds the ignition, change my key fob to passive and that will be it I think. That way I sit in the car, turn on the "power" button. The ignition wakes up, sees the key fob and I am immediately ready to start. This will drop my daily draw to under 10 milliamps. This should be fine during the driving season. I am also going to put a battery cutoff switch at the terminal for winter storage. The reason for the second switch just to the ignition and not what Mike did is I have an analog clock I don't want to reset every time I drive it. Once done (fingers crossed I don't make any new problems working behind the dash) I will document it all here.
09-20-2025, 06:38 PM
#575
09-20-2025, 06:51 PM
#576
JMD
I kind of agree. My true back out plan is to pull all of it out and put a regular ignition switch where the push button start is. I wanted something very specific with this build and a traditional key works against it but I won't hesitate if this turns into a hassle.
I think I am ok for now though.
09-20-2025, 07:32 PM
#577
Blitzboy54
Parasitic Draw Solution
So to tackle my energy hungry ignition system I needed to a way to get it off the battery. I am not prepared to pull it out. I have a DMV appointment on Tuesday and then maybe 6 weeks of driving weather. I am willing to sacrifice none of it. Mike had a the same problem and used a cutoff switch. My only issue with that is I have an analog clock in my dash and have no interest in resetting it every time I drive. Also to put this in context. I am losing 72 milliamps, so i am in no danger of the car not working day to day but if stored 2 months it definitely can be. If I remove the ignition from the circuit I draw 12 milliamps. This is perfectly acceptable for long periods of time.
When I connected the DGD to the RF harness I used a weather pack connection. So what I want is the ability to kill just the 12v hot going to the DGD. I created this to plug in between the existing harness and you can see I have a latching push button switch rated to 30amps.
I took out the brace I made for the dash under the steering wheel and mounted it.
The beauty of this setup is I changed my RFID tag to passive mode. I can leave it in my pocket, sit down, press my "secret" button and the system powers up and disarms. I then simply start the car. I can also just leave the switch closed and for daily use. But if say I am not going to drive it for the week (or month) I can shut it back off. It's not the perfect solution but it's the one I am going with.
Also since I am working on power disconnects. I wanted a disconnect switch but I had over thought the whole thing and had to back out of it. I found this item so I went ahead and installed it. I don't expect to use it a lot but it is nice to be able to kill the battery without wrenches. Like say the car is sitting for a couple of months over the winter somewhere in the Midwest while the body is getting painted.
I originally thought that a cutoff switch was cool and a nice 'safety' feature, but I wouldn't use it that much. I was definitely wrong. I've used it many times working on the build and for maintenance. It's so nice to be able to turn a switch versus disconnecting the battery cable.
09-21-2025, 01:38 PM
#578
09-23-2025, 07:13 PM
#579
Post Thanks / Like - 0 Thanks, 8 Likes
09-23-2025, 09:15 PM
#580
09-23-2025, 11:12 PM
#581
That’s what I call a good day! Congrats!
Build 2: Mk5 Complete kit | Coyote Gen 4X | TKX | IRS | Brake Booster | Traction Control | Ordered: 3/18/2026 |
Build 1: Mk4 Roadster | Coyote Gen 4X | Ordered: 1/31/2024 | Delivered: 4/11/2024 | First Start: 8/9/2025 | Legal: 11/5/2025 | Crashed: 2/16/2026
09-23-2025, 11:49 PM
#582
Beyond excellent. Better take the neighbour for a ride at some stage.
Nige
Gen1 Coyote / TKO600 / IRS
09-24-2025, 05:12 AM
#583
Did you buy a lotto ticket?!! If not, you better!!! Congrats, thats a good day off work. Well, any day is a good day off work i guess!
Higgy
MK4 #11354 picked up 10/06/25
MK4 #11173 picked up 01/20/25
MK4 #11012 picked up 04/16/24 SOLD
09-24-2025, 07:12 AM
#584
I love NY! DMV has gotten a bad reputation it doesn't deserve...probably because Patty and Selma Bouvier of the Simpsons work there.
Too bad we're in for another rainy day today.
Congratulations Jesse. I have flaring tools if you want to borrow them. But the poly hose you're using sounds like a better solution, especially since the wipers will be rarely used.
Joel
09-24-2025, 07:34 AM
#585
Great day. Another MK4 on the road. Agree NY is easier than all think, it just takes some patience and follow the steps.
09-24-2025, 07:40 AM
#586
Not a waxer
Congratulations Jesse!
09-24-2025, 07:53 AM
#587
NICE, Jesse!
It sure is a good feeling to have all that nonsense behind you, eh? Enjoy the fall weather driving!
Greg
09-24-2025, 09:16 AM
#588
Every now and then, the moon, the stars and the planets all align. It's a great feeling when it all comes together like that, especially back to back.
09-24-2025, 09:22 AM
#589
Wahoo! Congrats, Jesse! Light'em up!!
MK4 Complete kit.
Build Thread.
09-28-2025, 07:50 AM
#590
That’s a great story Jessie. Sometimes, not often, we get days like that. Great price with Hegarty. When I up the anti with American Collectors, sounds like a good second if the numbers aren’t right.
Now go get some miles on that beauty!
09-28-2025, 11:57 AM
#591
It's good to have friends
Thanks everyone for the kind words. The weather has been spectacular this weekend and I have a couple hundred miles under my belt now. It been great. I'm really glad I am driving in gel coat. It's the best way to shake it down. Things I discovered so far that needed attention:
1. Clutch was too tight, let it out and it hooks up real nice now. HOWEVER I get the strangest squeal in the clutch pedal. To my ear is sounds like the the pivot on the pedal needs lube but I can't be sure. It's a little odd. It comes and goes
2. Shift boot. I purchased a shift boot from Redline Goods. I used the Factory Five template but the hole on top is cut for the stock shifter. The coyote shifter is thicker. So I cut it and tucked it back inside. This doesn't really work for a number of reasons. I ordered another one and modified the top hole to 1 inch. I cut the top off the rubber shift boot and use it as a "gasket" to keep the heat out. I will share pics when my new boot shows up in a few weeks.
3. Seats - it did not occur to me that the seats might not be that comfortable but it might be the price you pay for buying custom seats overseas. I am going to play with seat angles this week and see if that improves it but my wife and I talked about it on our ride today, and I think what the real solution is when I pull the seats out this winter I am going to have the bottoms re done. Needs double the cushion.
4. ALIGNMENT
My friend Scott reached out to congratulate me on being legal and to tell me he had all the stuff at his place to do an alignment. I took him up on his offer. He said to plan on being there all day and he wasn't kidding. Home alignments are not for the faint of heart. Its extra hard without a lift because of access but we did manage to get it done. We started at 9:00 and finished at 4:00. We did walk up to the diner and grab lunch in there too.
The best part was the digital level kept resetting itself as the battery's were going so we chased our tails for a while until we figured it out. One time because we were both tired we set the camber to the prescribed -5 degrees. When I stepped back and looked the wheel looked like it had been in an accident. We couldn't figure out where we went wrong until Scott looked at me and said "wait, 5 degrees or .5 degrees"? I should have taken a picture. The best news is we got it done, took it for a test drive and the car drives fantastic. Straight as an arrow.
I can't thank Scott enough, that was a long day. I really appreciate it.
09-28-2025, 04:17 PM
#592
Blitzboy54
Thanks everyone for the kind words. The weather has been spectacular this weekend and I have a couple hundred miles under my belt now. It been great. I'm already glad I am driving in gel coat. It's the best way to shake it down. Things I discovered so far that needed attention:
2. Shift boot. I purchased a shift boot from Redline Goods. I used the Factory Five template but the hole on top is cut for the stock shifter. The coyote shifter is thicker. So i cut it and tucked it back inside. This doesn't really work for a number of reasons. I ordered another one and modified the top hole to 1 inch. I cut the top off the rubber shift boot and use it as a "gasket" to keep the heat out. I will share pics when my new boot shows up in a few weeks.
3. Seats - it did not occur to me that the seats might not be that comfortable but it might be the price you pay for buying custom seats overseas. i am going to play with seat angles this week and see if that improves it but my wife and I talked about it on our ride today, and I think what the real solution is when I pull the seats out this winter I am going to have the bottoms re done. Needs double the cushion.
4. ALIGNMENT
Glad to pay it forward!!! You and the rest of the Upstate Cobra club have done a lot to help me!
Scott
09-30-2025, 02:27 PM
#593
Blitzboy54
ALIGNMENT
Great to get an update. Glad you are getting out there and enjoying it with your better half.
The DIY alignment turned out to be one of the most satisfying parts of my MK4 build, and not a small learning experience. The proof is in how it drives. Way to go!
MK4 Complete kit.
Build Thread.
10-09-2025, 02:55 PM
#594
Post Thanks / Like - 0 Thanks, 4 Likes
10-10-2025, 09:29 PM
#595
Those bump stops do look like they'd give a nice ride. Are they hard rubber like a poly mount or on the softer side?
10-11-2025, 08:55 AM
#596
cv2065
They are definitely a polymer. These have a progressive design so they engage gradually. I went this route because it’s all entirely reversible. I plan to keep it as is but for resale or if I wanted a lower profile down the road these can be adjusted or reversed with a different set of wheels and it’s a totally different car.
10-11-2025, 09:32 AM
#597
Blitzboy54
Make sure you tighten the piston rod thread tightly in the rod-end. I had one unscrew and damage the thread.
Nige
10-11-2025, 03:07 PM
#598
Not a waxer
Jesse,
Coincidentally Mike Lewin with Professional Awesome is an old autocross friend of mine! His FFR is undergoing some serious revisions currently.
10-11-2025, 03:37 PM
#599
Nigel Allen
Nige
Good advice as always. I brought them down until they bottomed out, used blue loctite and tightend the jam nut. Appreciate you looking out.
I did a little data logging. I have a rural spot that's good for doing pulls. I ripped 3rd gear to 7k rpm. The continuous torque of the Coyote is really impressive. But I glanced down when letting off the pedal and I was doing 110 mph. I then suddenly was struck that I personally assembled this thing and am I sure I shouldn't double check all my connections before doing this again. We are building rocket ships
Should be respected accordingly
10-11-2025, 03:40 PM
#600
Jeff Kleiner
Jesse,
Tell him he has at least one duly impressed customer. He products are the secret sauce that make my wide stance roadster go.
Also I hope is revisions were planned.
