Parasitic Draw Solution
So to tackle my energy hungry ignition system I needed to a way to get it off the battery. I am not prepared to pull it out. I have a DMV appointment on Tuesday and then maybe 6 weeks of driving weather. I am willing to sacrifice none of it. Mike had a the same problem and used a cutoff switch. My only issue with that is I have an analog clock in my dash and have no interest in resetting it every time I drive. Also to put this in context. I am losing 72 milliamps, so i am in no danger of the car not working day to day but if stored 2 months it definitely can be. If I remove the ignition from the circuit I draw 12 milliamps. This is perfectly acceptable for long periods of time.
When I connected the DGD to the RF harness I used a weather pack connection. So what I want is the ability to kill just the 12v hot going to the DGD. I created this to plug in between the existing harness and you can see I have a latching push button switch rated to 30amps.
I took out the brace I made for the dash under the steering wheel and mounted it.
The beauty of this setup is I changed my RFID tag to passive mode. I can leave it in my pocket, sit down, press my "secret" button and the system powers up and disarms. I then simply start the car. I can also just leave the switch closed and for daily use. But if say I am not going to drive it for the week (or month) I can shut it back off. It's not the perfect solution but it's the one I am going with.
Also since I am working on power disconnects. I wanted a disconnect switch but I had over thought the whole thing and had to back out of it. I found this item so I went ahead and installed it. I don't expect to use it a lot but it is nice to be able to kill the battery without wrenches. Like say the car is sitting for a couple of months over the winter somewhere in the Midwest while the body is getting painted.
