Thanks Thanks:  50
Likes Likes:  156
Results 1 to 40 of 511
Thread: Rick's Mark V Roadster Build
Threaded View
  1. #11
    May 2022
    For those who were betting on electrical issues you were correct. The tech watched the video and said it was the starter not engaging. I explained the setup and what I had done/tested. He did not like the daisy-chain style of grounding the battery to the block. I suggested running a jumper cable directly to the starter mounting bolt and he agreed it’s a good place to start. I did it, but decided to disconnect it and try one more time to make sure the issue was happening before applying a fix to test. (My engineering background showing) And… it worked?!?!? Relief!!! He said that the issue is a bad ground and would probably come back. So I bought a long battery cable and connected the battery negative directly to the starter bolt and then a strap from there to the frame. Hopefully this is behind me.
    I then installed the throttle cable. I clamped the accelerator pedal to the front wall to simulate full throttle and used that to set the throw. I used this bracket. https://a.co/d/8PRfbd1
    I did have to redo the power steering lines. I had them backwards. Since the red cap was on the high-pressure side of the pump, I thought it corresponded to the red cap on the rack. Nick at FFR pointed out I had them backwards! Once I did that all the fittings needed WERE provided with the kit. I ended up using the provided SS line because there was no room to go direct with the cable I made. I had to pass through the wheel well and secured the cable to make sure there was no rubbing with the tire.
    I topped off the radiator with 1 gallon of AF and one gallon of distilled water. How do I make sure the engine has coolant? Spin the motor for a bit until the level stops going down? Thanks for all the help!!
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
  2. Likes rickshank liked this post
