Thanks Thanks:  50
Likes Likes:  156
Results 1 to 40 of 511
Thread: Rick's Mark V Roadster Build
Threaded View
  1. #11
    May 2022
    I called BP for support on what to do with the heater line. Their answer was for me to call CVF Racing, supplier of the front drive, to get an answer/solution. According to BP, the engine is dyno’d and then the assembly is added after. Do they do not test it?!??? That can’t be right. CVF was pretty condescending since I could not provide a part # or name of what “I purchased”. Even though I kept telling them it was part of a BP package.. Eventually they agreed to an email of the engine and issue.
    I decided that I needed to just make an adapter. So off to the store for components. Suffice is to say several hours later and several failed attempts I gave up and simply added a crimped bypass hose to get me past this hurdle. This won’t work as the ultimate solution so I’ll be dealing with support teams tomorrow. I never did get to installing the side pipes.
    Here is an explanation of my issue. Anyone else with AC & PS run into this and find a solution?
    The heater outlet on the water pump is pointing directly at the alternator.
    I thought I could build an adapter to go around it. But after much trial and error, I discovered there is just not enough room to build it where you leave enough space to secure the fittings AND be small enough to make the bends needed.
    There would be plenty of room if I could move the alternator over. I think that may be the ultimate solution. Getting a longer serpentine belt. Do they sell pre-bent heater hoses like they do with radiators? So frustrating! You spend a ton of cash so you get something that is supposed to be plug-and-play. You expect these kind of issues when you buy seperate components yourself..
    Build School: 5/2/2025
    Complete kit order: 5/8/2025, Delivery: 5/31/25, BluePrint 347 EFI + PS + AC order: 5/2/25 Delivery: 8/14/2025
    YouTube Channel
