Thanks Thanks:  35
Likes Likes:  50
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 109
Thread: The Baroness: MkIV Roadster Build Thread
    Apr 2023
    San Tan Valley, Arizona
    It's been a while since posting an update to the build. Truth is it's been hot. Really hot.
    And I've been doing some remodeling (re-did stairs, laundry room, etc)
    And getting ready for archery season (built a new bow, tuning and sighting in)
    And going to the lake....
    Anyways. I was able to get some work done on changing the wheel color and getting tires mounted.
    Turned out pretty good I think although there was some growing pains.
    Will be working to get the motor off of the run stand in preparation for stuffing into the body.
    Kit delivery (3/17/2024)
    FFR Mark IV Roadster (Ordered 11/9/2023)
    408 LS Stroker Powerplant Ready To Rock (link below of the first start)
    https://youtube.com/shorts/dH36tij3HK0?feature=share
  2. Likes Fman liked this post
  3. #42
    Apr 2023
    What has to happen before the motor can get installed into the chassis?
    Well it has to come off the run stand.
    Gotta start it up one last time first though. It's gonna be a bit before it will be ready to start up again.
  4. #43
    Apr 2023
    First time installing a dual clutch for me.
    Went together easy enough, just a lot of measuring
  5. #44
    Oct 2020
    Albany, NY
    I really like the red pinstripes on the wheels. Nice touch.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  6. Thanks Pmieras thanked for this post
  7. #45
    Dec 2021
    Flower Mound TX
    Is the bottom flange on the bellhousing going to hang below the frame rails? I know most people trim the Quicktime units for clearance.
  8. #46
    Apr 2023
    I'm not sure.
    I'll see what unforeseen issues I run into when I drop in the motor in the next week or so. I'm hoping I don't have to trim anything off.
    If I have to trim it I don't think I can take too much off. There's only about 1.5" until I'm at the flywheel.
  9. #47
    Apr 2023
    Wheels and tires go on in preparation for the engine to drop in.
    For some reason I was thinking this would help with the engine install.
  10. Likes M. Townsend liked this post
  11. #48
    Dec 2021
    Flower Mound TX
    I know adding those stripes to the wheels took a lot of time but they really set it off. Very nice.
    I like the little details like that, to me these things set a great build apart from an average build.
  12. Thanks Pmieras thanked for this post
    Likes Pmieras liked this post
  13. #49
    Apr 2023
    Thank you sir. Kind words.
    So far I like the stripes.
  14. #50
    Apr 2023
    This is gonna the last vid for a bit. Going bow hunting next week and I need to shift my focus until I get back.
    Motor goes in though and looks nice in the engine bay.
    It does look like I may have to trim the bottom of the bell housing (Just the tab that has 2 bolts).
    Doesn't look like it would be terribly difficult or take any substantial strength / protection from the bell housing.
  15. Likes M. Townsend liked this post
  16. #51
    Apr 2023
    It's been a while. Life happens but I think I've finally caught up to get back on the car...
  17. #52
    Oct 2020
    Albany, NY
    Hey,
    FYI, it looks like you have the trunk gas strut kit. Before you get too far along there it mounts right through that cubby wall. You have a few different options including using a prop rod but if you want to put the struts on that came with the kit you will need to make pass through holes. I used shorter struts and mounted mine to the floor on my first build after making this very mistake.
    Love the wheels. When done this car is going to be a looker.
  18. Thanks Pmieras thanked for this post
  19. #53
    Apr 2023
    Hey,
    Thanks for that comment and great tip. Didn't even cross my mind about the struts. Guess I haven't looked that far ahead. Lol.
  20. #54
    Apr 2023
    Install of the replacement shaft seal, driveshaft and safety hoop. A little difficulty filming this one. Got a really short tripod / camera stand on the way.
    Thanks for the feedback, suggestions, tips. I really appreciate it. It's what makes the community so great. Lots of good info.
  21. #55
    Apr 2023
    Slowly but surely... Getting a little scattered in the build right now. Work a little here till I get to a point where I need or waiting on something so then I'll work on something else.
    Radiator, shroud, battery tray and an update from Factory Five for the steering rack go in.
  22. Likes cv2065, lonestar, danmas liked this post
  23. #56
    May 2025
    Great build write up - big thanks, Paul! Very informative video content without a bunch of "fluff" like in some other build threads.
    Quick questions:
    1. Since I'm planning to PC my aluminum panels (which takes time) and don't want to just sit and do nothing, what else I can start to bolt on without aluminum panels installation dependency? Thinking of the rear suspension...
    2. Why everyone here insists on having the aluminum panels pre-drilled and installed before the PC? I may be missing something, but it doesn't make much sense to me doing this all prior to PC when the pre-drilled holes will anyways become a bit smaller because of the PC layer on top of bare metal.
  24. #57
    Dublin, OH
    Drilling panels after PC will likely cause it to chip and look unsightly. I'm guessing that's why most will PC after drilling. You may need to open the PC'd holes up a bit w/ a drill bit but overall safer than trying to drill through the PC w/o chipping it.
  25. Thanks lonestar thanked for this post
    Likes lonestar liked this post
  26. #58
    Jan 2019
    Mead Colorado
    Quote Originally Posted by Pmieras View Post
    Pretty much did exactly this today. It’s pretty satisfying to see things come together. I used the breeze lower radiator mount kit, but honestly a couple of slotted brackets, some tubing and a metal bar will work just fine. Nice video…
    Mk4 complete kit arrived 10 May 23
    Current BOM and Build Thread
  27. Thanks Pmieras thanked for this post
  28. #59
    Quote Originally Posted by lonestar View Post
    ...Why everyone here insists on having the aluminum panels pre-drilled and installed before the PC? I may be missing something, but it doesn't make much sense to me doing this all prior to PC when the pre-drilled holes will anyways become a bit smaller because of the PC layer on top of bare metal.
    Don't know if "insists" is the right word. Suggests is maybe a better one? Do it however you want. But reasons in my experience are: (1) Not unusual to have to tweak bends for the best fit. (2) A little more rare, but sometimes have to trim pieces a bit for the best fit. While PC might stand up to that, good chance of damaging while sorting everything out. (3) Common to mark pieces where the frame locations are, lay out the hole patterns, etc. so you know where to drill. Easy on bare aluminum, not so much on PC'd aluminum. (4) Just overall handling is reduced if they're ready to install after PC. Again, for less possible damage. Yes, the holes might be slightly undersized after PC. Takes very little time for each piece to run the holes through with the proper size drill bit.
  29. Thanks lonestar thanked for this post
    Likes lonestar, cv2065 liked this post
  30. #60
    Apr 2023
    Quick questions:
    I'm at the point where I'm kind of jumping around. Been thumbing through the build manual multiple times to try to avoid undoing something major because I did it at the wrong time. I'm sure I'm not going to be able to predict everything. Just trying to be smart about it.
  31. #61
    Apr 2023
    Quote Originally Posted by danmas View Post
    Agreed. I did the breeze bracket for the ease of it. Cost would have been negligible me doing it myself.
  32. #62
    Apr 2023
    I can see that. You might be able to minimize chipping by using a sharp bit all the time, go slow and be careful?
    My frame is powder coated and haven't had much issues but then again, those holes get covered with a panel.
  33. #63
    Apr 2023
    I noticed during my cerakoting process, due to sand blasting the parts, I've been warping the large pieces of aluminum (I have a video that showed that).
    Wasn't expecting that, but in my case seemed by ok. On the prices that I sand blast on both sides, the panel flattens back out. On the single sided pieces, I bent them back into shape over my knee.
    I'm not to familiar with PC so I can't speak for sure if there is any type of sand blasting involved as well.
    The buy that did my wheels sand blasted to remove the original finish prior to coating them.
  34. #64
    Apr 2023
    Slight error on my part, but not a huge deal. Had to take the fan shroud back off to mount the fan. Realized it as soon as I laid the fan on the shroud. You live and you learn.
  35. Likes Justin liked this post
  36. #65
    Dec 2021
    Flower Mound TX
    I hope you're not actually sand blasting and are plastic bead blasting instead. Sand is too harsh and not good for anything outside of industrial structural steel pieces. And ships. And bridges.
    Blasting a thin piece of metal can have the effect of shrinking the surface causing it to bow or warp. There's actually a science where the technique is used to form metal into a specific and complex shape. But don't look at me, I'm not nearly smart enough to do that.
  37. Thanks Pmieras thanked for this post
  38. #66
    Apr 2023
    Thanks for the heads up...
    If I remember right I'm using a 70g Aluminum oxide from Harbor Freight. The surface roughness it leaves is needed for good adhesion with the Cerakote.
    On the large panels I am getting some warping / bowing but so far it's been minimal and I'm able to straighten the piece back out.
    Nothing significant enough to have caused an issue so far (knock on wood).
    I've been able to minimize the warping by staying farther away from the work surface. Still warps a little, but the affect is reduce.
    The Cerakote sticks really well once fully cured and is quite durable. I've hit it with slips of the screw drive and such and it so far takes it without blemish.
  39. Likes Mike.Bray liked this post
  40. #67
    Apr 2023
    ICT brackets go on to put the alternator and power steering pump in their permanent home.
  41. #68
    Mar 2024
    Shawnee,KS
    Nice looking work, I really dig the wheels as it's basically what I have planned for my build.
    I wondered what the red stripe would look like on the inboard lip as opposed to the outer.
    I like the outer stripe like you've done.
    are you going to use the knockoffs or leave them off ?
    I'm planning on leaving the spinners polished on my upcoming build.
  42. Thanks Pmieras thanked for this post
  43. #69
    Apr 2023
    Quote Originally Posted by TrackDay17 View Post
    Thanks for the kind words.
    I'm happy with the stripe, took a few tries to get it right in my case.
    I'm gonna use the knock offs. Haven't decided if I'm going to do flat or gloss black, or bronze. Still kicking that idea around in the old melon.
  44. #70
    Apr 2023
    Rough in the power steering lines and drop in the belt.
  45. #71
    Apr 2023
    Install of the drivers side header while working out the cooling lines and fuel lines
  46. #72
    Dec 2017
    Love the videos! Just a suggestion. Header studs instead of bolts make the job a lot easier, especially on the driver’s side. They also save your header bolt threads from getting possibly stripped out.
  47. Thanks Pmieras thanked for this post
  48. #73
    Dec 2021
    Flower Mound TX
    I'll second the header studs and raise you Remflex gaskets.
  49. Thanks Pmieras thanked for this post
    Likes cv2065, Pmieras liked this post
  50. #74
    Apr 2023
    That's a great idea. I'm definitely going to look into that and the Remflex gaskets.
  51. #75
    Apr 2023
    I love the suggestions I'm getting from the forum. I just researched the studs and Remflex gaskets and pulled the trigger.
    I'm going to probably continue to use the gaskets the kit came with and use them during the build / mock up and change them out towards the end since I'm sure the headers are going to go on and off a couple times.
  52. Likes Mike.Bray liked this post
  53. #76
    Apr 2023
    Working on getting the heater core installed and run into a problem I need to sort out.
    I think I have a solution I'm going to do by modifying the heater core inlet / outlet. That will come out in a later video.
  54. #77
    Dec 2021
    Flower Mound TX
    You might be able to cut the copper tubes and fit these AN adapters. https://www.holley.com/products/plum...ts/AT165010ERL
    From there use a 90 degree AN hose fitting and maybe some hose like this or something similar. https://www.holley.com/products/plum...arts/650010ERL
    A heater in San Diego? That's interesting
  55. Thanks Pmieras thanked for this post
  56. #78
    Dec 2020
    Centennial, CO
    Same problem I had as well as others on here that installed the heater and using a 351 Windsor block. Throw the template in the trash and make your own. Do pay attention to where the wiper motor goes and the heater needs to be as low on the firewall as possible. I cut the tubes off and made a bead in the end using an Earls Performance EZ tubing beader that I got from Summit Racing. I think it was this one Part Number: EAR-010ERL. For a 5/8 tube.
    HEATER PIPES2.jpgHEATER PIPES1.jpgHEATER PIPES3.jpgHEATER PIPES4.jpgHEATER PIPES5.jpg
    Heater template:heater template.jpgheater template2.jpg
  57. Thanks Pmieras thanked for this post
  58. #79
    Apr 2023
    Quote Originally Posted by flyboyjy View Post
    Interesting. That might work.
  59. #80
    Apr 2023
    Not in San Diego but San Tan Valley, AZ. Definitely won't need it in the summer time.
    But some drives during the fall or early spring would be nice to have heat.
