12-02-2024, 11:50 AM
#201
Originally Posted by
ydousurf
Blitz, the dash looks awesome and thanks for the link to the vinyl wrap too! I was planning on doing my lower dash kick-out and trans tunnel in real carbon fiber, but maybe this an easier route to go? I’ll have to decide on which direction to go. Again thanks for sharing that info.
Jeff, here is a link to those seats. They are the model:
Stoneleigh - (Not cheap but you can go full customized with them).
https://intatrim.co.uk/products/stoneleigh/
I was considering getting those as well, but now I’m thinking of getting Corbeau Evolution X seats. I’m just not sure if these will fit?
Doug
I put these in.
Cobra Monaco Pro
https://www.cobraseats-usa.com/item/...pro/motorsport
They are the same size according to the website. My only caviet is I put a previous version in. I don't know if the updated ones are the same dimensions. Also when I say they fit, they JUST FIT. No wiggle room whatsoever. If I had needed them closer to the foot box I could not have used them.
I think you will be ok but I would mock something up before committing to the purchase.
Post Thanks / Like - 1 Thanks, 1 Likes
12-02-2024, 03:22 PM
#202
Thanks for the input/feedback, Blitz! Yeah, I really like those seats too! I’m actually looking for the option to have seat heaters installed in them, and that is why I was looking at either the Stoneleigh or Evolution. Plus, I am planning to make them swappable as to be able to switch between the original roadster seats for shows/cars & coffee and a head-rest version for autocross and highway driving. However those you have would give a much nicer “racer’s” feel I believe.
Doug
Dj or Doug or TheLateDude
----- #19 of 25th Anniversary MKIV 9769 -----
Build Link:
https://thefactoryfiveforum.com/show...-Slow-Progress
Ordered: Oct 07, 2019 / Production: Dec 28th, 2019 / Shipped: Jan 19th, 2019 First Start: In the future... / Graduation: Even further in the future...
12-02-2024, 05:08 PM
#203
Blitzboy54
As I round third base on the dash I wanted to add a handle and re enforce the dash. The number one thing you will end up telling everyone that gets in the passenger seat for the first time is not to use the windshield to support themselves. It is not load bearing. I like having a grab rail. It gives people something to use to sit and pull themselves up.
Where did you get that grab rail? Looks really good.
12-02-2024, 07:15 PM
#204
TXeverydayDad
Thanks man, I appreciate that. It’s a pretty standard marine grab rail. It was polished steel. I powder coated it in Prismatic Powder stone black. I picked it primarily because it fit in the space available
https://a.co/d/4OBExMi
12-02-2024, 07:28 PM
#205
I just ordered the same grab bar.
12-02-2024, 07:36 PM
#206
Are you able to share your center console design? It looks straight forward but would be nice to follow in your footsteps.
Dan
12-03-2024, 09:17 AM
#207
danmas
Dan
Sure, I didn't make a template or anything but I can take some detailed pictures and measurements if you want.
12-08-2024, 12:27 AM
#208
Blitzboy54
A few upgrade parts arrived.
First is the Ford gas tank filler seal. For those that don't know the grommet that comes with the kit that seals the filler neck to the gas tank is not OEM. FFR uses a Dorman part. There is a history of those leaking. I ordered the Ford part at my local dealer and I had it in a day. It was $32. Cheap insurance. Ford PN FZZZ9072DA
Next is the brakes. Wilwood uses what they call BP-10 as their standard brake pad. Regardless if you order from them or FFR this is what will come with them unless you tell them otherwise. I found them to be ok, but just ok. Some may disagree but I want my brakes to stop as aggressively and radically as my car accelerates. I did a lot of motorcycle track days in my 20's and 30's. My best times were all on lightweight bikes with huge brakes vs heavy fire breathers. I upgraded my fronts to BP-20's on my first build in the front. These are the most aggressive "street pad" Wilwood offers (everything else is a race pad). It made a significant difference. This build I want freakish stopping power so I am putting BP-20's on all four corners. They are not cheap but worth it IMO
The real exciting news is I got my panels back from powder coat. They cam out really nice. It's a metallic charcoal. I am going to use black rivets and I think it creates a cool look. The best part is I now have my color scheme worked out and it is all represented in my engine bay. Interesting twist is I was originally going to PC all the engine panels black again. I dropped them off with that as my order. The next morning I changed my mind to the charcoal. I already did the driver footbox. I plan to keep it black for now. I have some design ideas that I think will look really cool, but there is a scenario where I pull it back off and re do it.
Now that my F panels are in I was able to finish the front suspension. This should have been completely drama free but I discovered one of the downsides of having done this before is getting a little too comfortable. I make sure to keep the manual open and reference it. I got to the spindles and stopped reading at "DSS is the drivers side spindle". The rest of that sentence was for the hotrod. The roadster goes the other way. So I installed it on the drivers side before realizing it wasn't right. So I had to take it back out and fix it. I had to use a bearing puller to get it to pop off the lower control arm. Those are tapered. DOH
Any rate they are in and look good.
Do you have a powder coat color description or RAL number for the metallic charcoal? Where did you source the black rivets...McMaster Carr?
Jen
MK4 complete kit, IRS, Ford Strokers 347 (carb & mechanical fuel pump), TKX, PS, heater-defroster-wipers, firewall forward, 11.65 rear brakes, 17" Halibrands, #11124.
Ordered: 9.8.2024
Delivered: 10.31.2024
12-08-2024, 05:43 PM
#209
12-08-2024, 06:06 PM
#210
12-08-2024, 08:46 PM
#211
It's the little milestones that count, like the PB light! I love that. I built my last car without testing a single electrical circuit and I was a nervous wreck on 1st start. Everything worked but I was waaaaay out of my wheelhouse on that one.
I have a small 12 volt power supply but I probably need to check it's amperage to see what it can really power.
12-09-2024, 12:54 PM
#212
12-09-2024, 03:13 PM
#213
I really like the multi-functionality of the head unit. I will be doing something similar with cameras but integrated into a rearview mirror which will be overhead.
And there is nothing wrong with blue tape for the win.
12-09-2024, 08:36 PM
#214
PNWTim
That's awesome. Scott has one of those in his coupe. I thought about it but I don't have anywhere to cleanly run the wire unless I mount it to the dash. I want my rear view up high this time.
I look forward to seeing how you do it.
12-09-2024, 10:55 PM
#215
Jesse, have you tested that screen in daylight? I cant even read my 8" Fire tablet in full daylight hours with my Pro Flo 4 EFI app. The glare from the sun is terrible. Works fine during early morning, late evening and night driving.
12-10-2024, 12:50 PM
#216
Fman
Yeah, thanks Travis. I did test it out in the sun. It works pretty good, at least better than my phone. I’m going to give it a whirl as is. There are also anti glare films I can play with if need be.
Fman liked this post
12-10-2024, 10:38 PM
#217
Blitzboy54
Last I made the bluetooth connection with my phone. I tested it with maps to navigate to this totally random place that I have never been to to see how long it would take to get there.
Looks great, Jesse! Many cool features in your build. You're moving at warp speed! Are you having as much fun as your first build? I know I am. Keep up the great work.
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
12-11-2024, 09:57 PM
#218
460.465USMC
Thanks Chris. Always good to hear from you. Yes sir, I’m having a blast. I think the pace of the build reflects that. I really like being in the garage.
Looking forward to seeing some of your updates.
12-12-2024, 10:46 AM
#219
Blitzboy54
I can totally relate. My family bought me two tee shirts during my first build. The first one says, "My garage is my happy place". The second says, "I can't. I have plans in the garage". Not that I would ever say that.
I bet you'll be at First Start before long. Will be exciting!
MK4 Complete kit.
Build Thread.
12-13-2024, 06:53 PM
#220
12-13-2024, 07:04 PM
#221
12-13-2024, 07:28 PM
#222
Looks great Jesse!
Are you planning defroster ducts for the 2nd build or is there a workaround for NYS registration and inspection?
Tilton 90deg elbow...did you change out the MC's for Tiltons? I've been reading about the recent failures.
Turn signal hub...did you substitute the horn function for high beam operation or is there a separate stalk button? Is it latching or momentary? I watched Frank's video for adding the high beam relay but is the other wiring a direct connection to the RF harness?
Jen
Ordered: 9.8.2024
12-13-2024, 07:38 PM
#223
jengum
Looks great Jesse!
Ducts on a roadster are useless if you don't have a top. I will temporarily put defroster grills on the body when I register. Then ditch them.
The elbow has nothing to do with the MC, just happed to both be made by Tilton. The 90 is the only way to get the cable to fit and function in the space available the way I want to do it.
Franks hub uses the stalk for the horn. Pull it and it becomes a momentary switch. Everything else just wires to the RF harness.
12-16-2024, 09:47 PM
#224
Post Thanks / Like - 0 Thanks, 4 Likes
12-16-2024, 10:43 PM
#225
Yeah, buddy! Great feeling getting those lights and gauges lit, eh? I just did this same thing for the first time Saturday.
Greg
12-26-2024, 04:08 PM
#226
12-26-2024, 08:38 PM
#227
I think there may be something wrong with your display on your daily driver - there's a negative sign in front of the 4!
Great progress and pretty perfect those wheels and tires are a fit. I feel a first start coming to a theater near you...
12-26-2024, 09:10 PM
#228
-20 Celsius! I can't even imagine that. Closest I have ever experienced anything like that was fixing an electric forklift in a blast freezer. After 30 minutes I thought I would die before the repair was done.
We had 101F on Christmas day.
Nige
Gen1 Coyote / TKO600 / IRS
12-27-2024, 05:55 AM
#229
PNWTim
Nigel Allen
Nige
The older I get the less tolerance I have for the dead of winter. Good chance my kids stay in the Northeast which means by default we would too. If that happens my first retirement project will be to find the cheapest tear down ina warmer climate and build me an escape hatch.
Ideally a tiny home with a 3 car garage.
12-27-2024, 10:10 AM
#230
I’m ALL over the tiny home with big garage. As long as my wife has animals running around, she should be good as well!
01-04-2025, 05:28 PM
#231
01-04-2025, 05:42 PM
#232
01-04-2025, 07:54 PM
#233
Not a waxer
At least you found the bellhousing to flywheel interference before dropping the engine and trans in. Unfortunately I didn't on a Coupe that I did a couple of years ago
01-04-2025, 08:39 PM
#234
Jeff Kleiner
Jeff,
Literally the ONLY reason I even knew to check was I found your thread and bookmarked it 6 months ago.
https://thefactoryfiveforum.com/show...bytrap-warning
This forum is a national treasure.
01-18-2025, 05:58 PM
#235
01-18-2025, 06:12 PM
#236
01-18-2025, 06:33 PM
#237
01-18-2025, 11:29 PM
#238
Looks great Jessie. Definitely a lot going on in the engine compartment. I think Coyotes are standard rotation (clockwise from the front) so you should be OK unless the motor gets wider below what you show in the picture.
01-18-2025, 11:51 PM
#239
Nice work Jessie! Definitely standing room only in that engine bay. And I thought my header fitment was tight on the driver's side! I still think you'll finish before I do.
01-19-2025, 11:47 AM
#240
That's a lot of yoke showing out f the transmission, are you sure you have the correct length driveshaft?
Man those Coyote's are stuffed in there, I guess you install the header bolts from the bottom?. Installing one is definitely above my skill level. Hats off to you!
