Its Bruce
I ordered one from Amazon and will test this weekend. Thank you for showing me that. I have some concern if tucked into a tight space behind the dash the wire feedthrough style might have some interference.
JohnK
I'm pretty sure that E-Stopp also uses a current sensing relay to control cable tension/travel. From their FAQ:
[FONT="]Q: How many inches of travel does the E-Stopp have[/FONT]?
A: About 2 inches. Most systems only need about 1. The motor stops itself once it reaches 600 pounds of resistance.
That makes sense, thanks. I guess with this arrangement if you wanted you could use a stronger longer throw actuator as long as the relay worked it would matter.
John, how is the car treating you? She is really a beautiful ride. I love the black contrast against the chrome and silver. I'll bet you get a lot of attention.
smccoy
Looking good! Do you have a source / part number for that spring? I'm using the same actuator and will be doing the same testing shortly.
Yes sir, I think if I go with a spring I will use a closed loop version of this, but this is the one I used.
https://www.mcmaster.com/5667N404/
Blitzboy54
Thanks Jesse! I appreciate it. Yes, like all of our cars, she draws a lot of attention. I'm loving what you're doing with this build so far.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
Finally catching up on Build Deux. First of all, congrats on delivery and all the great progress so far. The C8 orange was one of my top three color choices if I would have painted my Roadster (now sold). I'm a sucker for orange. Love it.
What a bummer on the first two motors. So glad the sellers made it right. Your Gen 2 will give you more than enough power to blow your hair back (IMHO). You will love how it likes to rev high. And the power band...just a blast to experience! My Gen 3 really kicked in at ~4K RPM and higher.
Regarding your earlier IRS torque question (100 lb ft v. 129 lb ft), I torqued both mine (Roadster and Coupe) to 100 lb ft. Back on my Roadster build, I had the same question about the torque discrepancy in the build manual, so I emailed F5. Dan G. wrote back with "100 lb ft is fine". FWIW.
Subscribed and looking forward to following along. Just like our first Roadster builds, I suspect your build will zoom right past me. Enjoy!
Coupe complete kit. Index. Delivered: 4/22/24.
Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
460.465USMC
It’s always great to hear from you Chris. I have been following your Coupe. I really appreciate your input on the center section torque and I’m really excited about the engine. Had I known factory re manufactured engines were a thing I would have started there. I couldn’t t find a Gen 3 and then started looking used.
Also YOU SOLD IT!?!?! Did you get what you were hoping? Interesting strategy to list it pre paint. That could be an asset or a liability.
I like your wheel choice. Right on! I'm seeing we have similar tastes: C8 orange and the wheels. Nice. I made a note of the BP-20 pad option. (I was a bit underwhelmed with my Roadster braking using Wilwood Dynapro with stock pads. I may eventually do the same, but first want to see how the Coupe stops. I'm running the Wilwood six piston Superlites up front this time around, so a bit more surface area for braking grab).
MK4 Complete kit.
Build Thread.
Bravo Mr. Blitz, Bravo!
..Love Those Wheels!
Great choice of wheels!
Keep up the progress
Mark III 4630RD Explorer 302, Holley SA570, FRPP B-cam, 4 to 4's, 3 Link, Bullitt wheels, Baer Brakes, 3.73 gears, HD T-5
Mark II Rebuilt into 1955 Jaguar D Type Replica Explorer 302, Holley SA670, Trick Flow Stage 1 cam, 3 Link 4.10 gears, Classic Gauges
PM me if you live in Upstate New York. Get added to the
"Upstate Cobras" email list. 60+ members!
Parking brake - Final solution
So what I needed to make this work in both directions is hard stop on release. I took some measurements and ended up replicating my pull solution to fix my push problem.
The brackets I ordered came in a 6 pack so I have spares
This creates a hard stop that allows it to work as designed both directions. If I need to tighten the brake I simply turn the pot counter clockwise and increase the current limit.
I will add a physical or magnetic switch when I get to the wiring that will carry another 12v signal that will light the dash. It will either be NO or NC and send 12v to the dash when the brake is engaged. I do not expect this to be expensive.
So a rough tally of what I have in the mod. Prices to not include tax.
Actuator= $40
Clevis = $36
Over current board = $12 (spring was $15 if you went that route)
L brackets = $20
Switch = $8
The various hardware I had laying around from my last build, but if you didn't have it probably another $10 at the hardware store.
R&D costs are sunk so I am not counting that. That is a functional electronic parking brake for under $120. I expect the switch to cost no more than $20.
Not bad.
That's pretty clever. Assuming since you patched the hole you will ditch the hand brake altogether?
PNWTim
That is correct. I was never happy with the original location. It was either going to be on top or electronic.
Looking this over...
I feel like a ham handed hack.
Great work!
$3400 for orange calipers? you could likely get then re-PC'd locally for much cheaper. a pop of orange under the black rims would look really sharp w/ your color combo.
egchewy79
It was a combination of 2 things. The kits themselves are roughly 25% more expensive if you order directly from them. FFR must get a volume discount and passes that on to us. The other is they wanted $575 per caliper for custom coating (unclear if that includes he parking brake). So add all that up and it was about that much.
I agree the orange would really pop. I could get them done locally but I don't think I could keep the logo. Maybe I shouldn't care but oddly enough I do. I will ask around. It would have to be done before I put fluid in them.
09-30-2024, 01:38 PM
#100
That's awesome! Great out of the box solution. I'm putting mine on top as well, but manual style. Great job!
09-30-2024, 02:44 PM
#101
Blitzboy54
Actuator= $40
Clevis = $36
L brackets = $20
Switch = $8
Not bad.
Nice work my friend.
Nige.
Gen1 Coyote / TKO600 / IRS
10-04-2024, 08:46 PM
#102
cv2065
Nigel Allen
Nige.
Thanks guys, I appreciate it.
Engine intake and Fuel lines
One of the things I have been kicking around is what intake manifold I want to run. The Boss 302 is by far the best looking option on a budget but doesn't perform as well in a non boosted application. I was pretty close to pulling the trigger on a super charger but ultimately I have decided against it for a few reasons. First and foremost is the cost. I can do it for roughly $5k with a torque storm setup. This isn't bad but I am hilariously over budget already. Second is longevity. I do worry that I would wear the engine down over time and then need to pull it early and replace who knows what.
Having said that I want the best performing arrangement possible so I reached out to Lund. They said hands down the best setup for a Gen 2 Coyote is a Gen 3 intake with the IRMC locked out. So this is what I decided to do. Interestingly there are 2 PN's for this manifold. There is the Ford Performance M9424M50C this sells for just under $500.
Then there is the Genuine Ford JR3Z-9424-B. I cannot find a difference between these parts. I found one site that referenced "improved IRMC performacen" on the new PN but with that locked out I can't imagine it would make a difference. Since the Genuine Ford part sells from the dealership for $200 less I went with it.
I like the black look anyhow. I am going with black valve covers so this should help with the look.
Locked out IRMC
On fuel lines last build I used soft rubber and then changed to stainless steel when I upgraded to an in tank pump. I had some left over and tried to straighten it, this is as far as I got before I tapped out.
I just hate the way it looks so I bit the bullet and ordered two 8' pieces from McMaster Carr. I went with a thicker wall at .035. In my mind money well spent
10-04-2024, 08:55 PM
#103
10-04-2024, 09:40 PM
#104
Hey, I recognize some of those Coyote parts! Glad to see them coming together on your build. Looking great!
Greg
Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, ReplicaParts
MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, First start 3/15/25. Legal 6/13/25. Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
10-04-2024, 11:28 PM
#105
Lines look great. Well done!
10-05-2024, 10:38 AM
#106
gbranham
Greg
You certainly do! Glad that worked out.
10-06-2024, 06:20 PM
#107
10-09-2024, 05:51 PM
#108
10-09-2024, 06:13 PM
#109
10-09-2024, 09:53 PM
#110
What car computer did you get? I will do much the same but haven’t decided on which one yet…
10-09-2024, 10:12 PM
#111
Glad to see my tools get a workout! Better than collecting dust on the bench!
10-10-2024, 09:08 AM
#112
danmas
I am using this. It is not particularly expensive. I really don't think it needs to be but it will be installed in such a way that it will be upgradable later if need be.
https://www.amazon.com/dp/B0CN94Z1ZM...sin_title&th=1
10-12-2024, 10:42 AM
#113
Blitzboy54
Great solution, Jesse! Nice. If you can use them, I have a set of new Gen 1 valve covers you are welcome to (free).
Blitzboy54
It makes a massive difference starting with a nice straight piece of pipe. Started bending and just slowly worked through it. I completed the hard portion of the return line.
Boy, those SS hard lines just look tight. Hard to beat the function and asthetics to boot. Great work, sir!
MK4 Complete kit.
Build Thread.
10-13-2024, 11:26 AM
#114
460.465USMC
That's really nice Chris, Thank you. I checked it out and they are compatible. Ford makes a Gen1-2 cover thats all black I was planning to use. I assume yours are grey? I could paint them though. Would be pretty easy to do. I will DM you.
Really appreciate it!
10-13-2024, 11:42 AM
#115
10-13-2024, 11:51 AM
#116
10-13-2024, 12:07 PM
#117
10-14-2024, 05:52 AM
#118
Great documentation Jessie!
10-17-2024, 09:32 AM
#119
Wow, Jesse, way to make hay after getting the kit! You're moving right along! And while your first build was something to be proud of, I can see how the game gets upped on a second build. Really nice build going. The 3/8" spaghetti noodle AutoZone line ... yep, I remember that part. Good choice moving away from that. The rear brake lines ... yep, I kept them inside the DS footbox as well, but didn't have the challenge of the Coyote go-pedal. Might seem a bit wonky ... but only to you. Just as functional and reliable, and no one else will see it. Good choice.
Parking brake - great job. Look at that guy stick to a budget (so he can blow it in other places)! Seriously, I'd suggest you do a separate post in the main roadster forum once you've got everything dialed in. Photos, bill of materials, etc. It'll get copied widely, I'll bet.
Looks like you're having a blast. Thanks for sharing in another build thread!
Meandering, leisurely build thread is
here
10-17-2024, 10:23 AM
#120
Nice work Jesse, I am really curious how the e-brake location will work. Will that be accessible for adjustment once the body is on?
