Thanks Thanks:  84
Likes Likes:  481
Page 17 of 18 FirstFirst ... 715161718 LastLast
Results 641 to 680 of 685
Thread: 25th MKIV #9772 Build NOR*CAL: new vanity plate
  1. #641
    Folsom, CA
    The cobra is home! Everyone is asking what the car's name is... LOL, I have no clue! Give me some ideas!
    Also, I took the car to our local Cars & Coffee - got a LOT of eyeballs on it!
    Todd
  2. Likes ydousurf, Ted G liked this post
  3. #642
    Folsom, CA
    adjusted the ride height in the rear, the front is perfect at 4" and the rear was also 4" - we raised the rear to 4.5" because over bumps the 315s out back would rub the body a bit
    took the car for alignment - to a place I've never used, but was recommended
    unfortunately they didn't feel they could adjust the camber properly without disassembling the front upper arms and placing shims to bring the camber up
    For a car using power steering car use the following specifications:
    Caster: 7
    Camber: -0.5°
    Total Toe: 1/16”
    2015 IRS only
    Camber: -0.5°to -0.75°
    Total Toe: 1/8” Toe in
    they wanted $800 to do this... needless to say I paid them $35 for a diagnostic fee and drove home... will hit up another local spot that i KNOW has worked on FFRs before
    Todd
  4. #643
    They clearly don’t know what they’re doing.
  5. Likes toadster liked this post
  6. #644
    Owning two of the eyeballs that were on your car that day I will confirm the collective oversized thumbs up there was on it! Nice job!!
    Pretty sure Eddie at Tire Pros will do it. They did my 33 and it's a PIA. And they only charged me like $180 I think for 4 wheel.
  7. #645
    Folsom, CA
    Some small adders today - did the rear view mirror, side mirrors and the wind wings
    also installed the Breeze radiator cowl cover, this was a tricky 1 man job
    Thankfully I pre drilled everything prior to the body going on, I really like how this part buttons up the front of the engine bay and will keep the air flowing through the radiator and not up and over the engine
    also added the side badges
  8. Likes Railroad, Ted G liked this post
  9. #646
    Folsom, CA
    simple stuff since it's 112 outside, garage is barely keeping up around 86-89 with the A/C running...
    visors and rear view mirror - with square nuts this time
    a LOT of sanding/grinding to get the 8-32 nuts to fit into the windshield channel (for the mirror) - but much easier than trying to hold a hex nut with a screwdriver (because they spin)
    also hooked up the fuel filler hose and ground strap - now I can actually get some gas in the tank, will probably do 1/3rd of a tank to get it aligned this friday
    also working on the license plate light wiring, and adding an LED light bar to the filler plate to light up the trunk a bit more when the interior lights are on (pics to come!)
    also, the rear view camera/backup light setup with my license plate frame won't work in the current setup, either the camera on top blocks the license plate lights, or with the camera on the bottom, the trunk won't open
    more planning needed !!
    Last edited by toadster; 07-08-2024 at 11:56 AM. Reason: the 6-32 nuts fit perfectly for the visors
    Todd
  10. Likes Ted G liked this post
  11. #647
    Dec 2021
    Flower Mound TX
    a LOT of sanding/grinding to get the 8-32 nuts to fit into the windshield channel - but much easier than trying to hold a hex nut with a screwdriver (because they spin)
    You're not going to like this but if you use 6-32 square nuts they slip right in. Got that from Mr. Kleiner.
  12. #648
    Folsom, CA
    yes I used 6-32 on the visors, but couldn't get them to work on the rear view mirror... had to go with 8-32
    Todd
  13. #649
    Folsom, CA
    got my new appointment to get aligned, the guys at BigO didn't disappoint! only $129 and 1.5 hours - dialed in!
    Todd
  14. Likes Ted G liked this post
  15. #650
    Those are good numbers Todd. Set your tires to 22-23psi and the car ought to drive great!
  16. Thanks RobHartley thanked for this post
  17. #651
    Folsom, CA
    Thanks Jeff! I've been wondering about the tire pressure... I believe they're at 35psi right now, but tracks EXTREMELY well compared to previously!
    If I check the Yokohama site it says this:
    The optimum 'working' tyre temperature of the Yokohama Advan A052 is around 40 degrees Celsius, with a temperature spread of 10-15 degrees across the tyre tread area.
    Yokohama recommend the following technical set up: Optimum hot pressure dry use 2.0 - 2.2 bar or 29-32lbs. Minimum cold air pressure is 1.4 bar or 20lbs
    Todd
  18. #652
    Trust me, the car isn't heavy enough to create full tread contact when they are run that high. With that much pressure the tire will be overinflated for the load and only running on the center of the tread.
  19. Thanks toadster, RobHartley thanked for this post
  20. #653
    Folsom, CA
    tidying up some items before the inspections... one item was a VERY touchy brake light - we thought this was resolved prior to the body going on, BUT it stayed...
    crawling into the driver footbox is a contortionists dream! fortunately the seats aren't attached yet, so that simplified things a bit
    the problem is that with the Whitby power brake pedal and the Wilwood pedal setup is that the mount point for the brake switch is about 1/8th of an inch too short with both hex nuts attached
    this would cause the brake lights to stay on, and would actually 'flutter' when driving because the switch was right on that edge on open/closed when driving and the pedal riding on the switch
    we need the switch to move closer to the brake pedal by about 1/8" of an inch that nut is just a bit too thick!
    getting into the footbox took sheer will, and some stretched neck muscles for sure!
    this is my son Ryan (who is 6'3") and barely can get in the footbox, I'm sure I filled in the space a bit more LOL
    the goal was to use a crescent wrench to loosen the top nut while keeping the switch intact to allow us to remove the switch and the nut behind the switch and replace it with a simple washer, not sure if this will hold over time but need to get this fixed or it won't pass brake and light inspection
    with a thin washer in place of the nut, and hopefully tightened down enough the brake pedal switch is now kept open at rest, and works as expected - need to go-kart a bit more to test it out
    you can see the much thinner washer and it moved the switch ever closer to the pedal bar
    Todd
  21. Likes Ted G liked this post
  22. #654
    Folsom, CA
    doing more post-paint checklist items:
    1. shortened the seatbelts a bit more, I tell that that's fun with the body on! it helps to have the speakers removed though to get a few hands in there! Now they're pretty snug, and I feel better to attach the seats and submarine belt.
    2. figured out my turn signal/dash flashing issue - was a bad LED bulb, I put the incandescents in for now in the front - a replacement LED is on it's way and I'll test again
    3. buttoned up my dash and re-installed the speedometer (which was removed to ease access behind the dash when we were chasing the weird electrical issue in #2)
    4. fixed a bad ground in the rear of the car, essentially the ground to all the trunk lighting was dead, installed a new ground in the trunk and all good
    5. installing an LED in the trunk cover (from DWC) to give more light from the top/inside of the trunk
    6. was fidgeting with the license plate lights, how we found the bad ground, and I snapped off the screw
    7. #6 forced me into my backup camera install, got things drilled, now I just need to mount it
    Todd
  23. Likes ydousurf liked this post
  24. #655
    Folsom, CA
    had more fun finishing up the rear view camera setup... not for the light of heart for sure
    from my last post, since the screw post snapped on my license plate light, this is the time to get this mod done - was going to wait for after registration, but - without the light cover attached, I figured it would fail inspection
    now - in order for the camera to fit into the light fixture, the grounding bar is in the way where the camera will sit - the nice part is that the ground bar is a bit higher than the actual camera spot I located, just a hair below the screw post
    I used the 18.5mm hole saw and cut a raw hole
    notice that the bar still is connected, so there's ground continuity to both lights for the license plate
    next up, I needed a little more width for the screws I was going to use , the ground bar isn't wide enough, so two 1/8" holes were drilled and I added a small aluminum bar to overhang the grounding bar a bit
    using some small rivets, I was able to place the two the extension bar just between the ground and positive bars, without touching - there's plenty of clearance
    top view of the result - the new #25 holes with #10-24 tap will be used next
    Todd
  25. #656
    Folsom, CA
    next up, spacing out the exterior screws, I used #10-24 since I have a boatload of them
    measured equal distances from center and use a 7/16 bit for the bolt holes
    once the exterior holes were drilled, then I could use a #25 drill bit and then tap the holes for 10-24 screws
    also note, I had to use the 18.5mm hole saw on the added aluminum bar as well
    hopefully you can see the tolerances between the lights, screws and positive/negative bars
    Todd
  26. Likes 460.465USMC liked this post
  27. #657
    Folsom, CA
    here's the camera I used - 1080P Backup Camera
    we had to clock the camera a bit to get it aligned, pretty simple after all the installation
    and the finished result
    Todd
  28. Likes Fman liked this post
  29. #658
    Jan 2020
    State of Jefferson
    Nice work Todd, how is your A/C working for you? Can you drive the car on a 90+ degree day and not turn into a baked potato?
  30. Likes toadster liked this post
  31. #659
    Dec 2021
    Flower Mound TX
    That backup camera is neat, it would be handy to have on all the time as the rearview mirrors I have don't give the best view. I doubt if I have the energy to add it to a finished car though.
  32. Likes toadster liked this post
  33. #660
    Folsom, CA
    to be honest, on a finished car it would be a bit of a chore with the wiring, neat idea for always on, but then I'd never see the radio screen
    it does rather well! keeps the footbox nice and cool, got sunburnt yesterday not realizing how much sun was on us! LOL
    Todd
  34. Likes Fman liked this post
  35. #661
    Aug 2019
    Spokane, WA
    A backup camera in the license plate light housing...who would have thought? Pretty cool! Things are coming together very nicely, Todd. Looking great!
  36. Likes toadster liked this post
  37. #662
    Folsom, CA
    did my first fillup last night, I even got .10c off per gallon, stupid CA gas prices
    and before you ask, this is the Boyds gas tank
    Todd
  38. #663
    Folsom, CA
    a few more things to get the build a few more steps along...
    installed an LED into the DWC filler panel, this adds a TON of light into the trunk - as you can imagine, stuffing your trunk full of stuff can block the trunk lights - this gives you a nice overhead light to see
    added my exhaust hangers, and used rivnuts like many have so I didn't have to bolt through the 2" square tubes
    I'm using the Gas'N hardware and may change over time to a different exhaust hanger setup, but these Coyote 4-in-1 headers mount pretty well to the Gas'N side pipes
    note: pics below are basic setup, not fully tightened down
    lastly, also mounted my Drummer Mike Side Pipe Shields - these are REALLY nice quality!
    I tweaked my install a little bit... added some high-temp gasket material to the exhaust wrap that sits inside the bands between the exhaust pipe and the shield - REALLY simplified installation by holding the gasket in place!
    Todd
  39. #664
    Folsom, CA
    I also used some leftover zero-clearance shielding from Breeze Automotive to add another layer of insulation to really reduce temps
    will do some temp comparisons soon to show the heat difference...
    CHP inspection tomorrow!
    pre-drilled my plate mount
    getting closer to being fully registered!!
    Todd
  40. Likes ydousurf liked this post
  41. #665
    Jan 2020
    State of Jefferson
    FWIW If your pipes start to sag you can toss out that rubber grommet and go with thicker exhaust straps which won't stretch out and will hold the pipes level. Those drummer mike shields look great, it's too bad he stopped making them... top notch quality!
  42. Likes toadster liked this post
  43. #666
    Folsom, CA
    thanks Travis - I have those straps on my Amazon wishlist will see how they go - these 4-into-1 header flange mounts are pretty sturdy - the pipes seem dead on after 195 miles so far but now at least they're supported a bit more now
    agree, the drummer mike shields are excellent quality - I got them just as prices doubled! ouch!
    Todd
  44. #667
    Dec 2021
    Flower Mound TX
    I wrapped one of these around the rubber grommet to give it some extra support without taking out all of the flex.
  45. Likes toadster liked this post
  46. #668
    Folsom, CA
    cool idea! I could probably even use a 4" metal bands and tighten down, may come loose over time though...
    also, here's a temperature pic of the exhaust - the Drummer Mike Shields with the zero-clearance makes a HUGE difference!!
    the pics were taken about 3 minutes after the car was shut down - yes that's 53 degrees cooler with the shields and insulation!
    another postitive today, passed brake and light inspection ($225 eek!)
    also got my VIN # from CHP, just need to wait for my SPCNS number to be assigned to visit the BAR Referee to finish my SB100 - then back to DMV to finalize plates!
    Todd
  47. #669
    South Australia
    Hi Todd,
    I have similar shields on my side pipes (legally required here) although drummer Mikes are nicer . They work well.
    The temperature readings you are getting may be false as infra red sensors don't get along well with reflective surfaces.
    Nige.
    Gen1 Coyote / TKO600 / IRS
  48. Likes toadster liked this post
  49. #670
    Dec 2021
    Flower Mound TX
    Or curved surfaces. We use contact thermocouples in these types of situations.
  50. Likes toadster liked this post
  51. #671
    Folsom, CA
    little things while I wait for my SB100 paperwork to arrive... slow process, but at least nearly done!
    added the rear fender shields and the whitby fillers for behind the seats
    it's crazy the size of the gap in the rear wheel well
    not a pretty install, I had to flip both parts top/bottom to fit the body spacing - but it will seal up the wheel well, and honestly who sees this?
    have a car show this saturday - no plates yet, but hopefully nobody will complain
    Todd
  52. Likes Ted G, 460.465USMC liked this post
  53. #672
    Folsom, CA
    another pic of the rear shield (passenger side) used Raptor bedliner coating - it's not super thick (at least the spray can version) but it will hopefully remove some of the resonance/tinny sound for rocks
    In case you're wondering, the blue hose is my fuel vapor canister (link to install)
    Todd
  54. #673
    Jan 2020
    State of Jefferson
    IMHO, these are worth the $$$ will prevent any starring in your paint from a hard rock hit in you wheel well.
    http://vraptorspeedworks.com/mk-4-wheel-well-liner-kit/
  55. #674
    Folsom, CA
    Thanks Travis - yes they're on my list, will have to customize them a bit due to the footbox blowers in front - I think you re-purposed your blowers right? any pics of your liner install?
    Todd
  56. #675
    Sep 2018
    SF Bay Area, CA
    I agree with Travis on the recommendation for the wheel well liners. Besides giving a clean, finished look they will prevent rocks from being kicked up and hitting the underside of the body. Bed liner on the underside will protect, to a point, but IMO these provide far more protection. Here's a link to how I installed the rear liners. I didn't post an update to my build thread about the front liners, but they're basically the same process, other than coming up with some way to secure the front of the liners. One note worth mentioning, splash guard positioning is important, as it will determine how deep into the wheel well the liners sit. If the splash guard is close to the edge, the wheel well liners and their bulb seal will be very close to the fender lip. I wanted them a bit recessed and out of sight so I ended up doing a bunch of trimming to the splash guards to set them further back than the typical install to give plenty of room for the wheel well liners.
  57. Thanks toadster thanked for this post
  58. #676
    Folsom, CA
    it's been a long 2 months waiting for my SB100 build number
    I got #120 for 2024, assigned in September, but not mailed to me until 2 days ago - yes it took 2 months to get a piece of paper to allow me to move forward - crazy!
    I talked with the BAR Referee yesterday, he called me early because all my paperwork was in order, and the photos were just what he needed. Yay for being thorough
    I have my appointment on November 19th to have the visual inspection and pass my SMOG verification, then I can finally go back to DMV and get this car registered
    I have almost 600 miles on the car now, going to replace the oil, trans fluid and differential fluid just to make sure things are good and check for any metal, etc.
    I'll probably do an Oil analysis https://www.blackstone-labs.com/free-test-kits - the kits are shipped for free, just pay when you get the analysis done
    for me it's a great way to see how things are wearing, etc. like a blood test by your labs for your annual checkup
    Todd
  59. Likes 460.465USMC liked this post
  60. #677
    Sep 2018
    SF Bay Area, CA
    Congratulations! This part of the process definitely tests your patience but well worth it in the end. BTW - if you want a personalized plate, expect to wait another 9 months
  61. Thanks toadster thanked for this post
  62. #678
    Folsom, CA
    well it's taken 10 months, but I now have a fully registered car in California! SB100 #120 for the year which is pretty low considering they offer up to 500 of them each calendar year!
    pretty excited to get this part done and registered! about 640 miles on the car so far and it's been awesome!
    Todd
  63. #679
    Folsom, CA
    Believe it or not, I've put about 1,300 miles on the car and realized that I hadn't put the door cards on! They were tucked away on a shelf in the garage, so I pulled them out and gave the leather a good treatment.
    These match the FFR seats, transmission tunnel and radio box upholstery.
    I was really adverse to drilling into my doors, so I opted for some really strong velcro. It's maybe overkill, but everything in this build has been like that.
    I used VELCRO Brand Extreme Outdoor Double Sided Mounting Tape | Holds up to 15 Pounds on Brick or Other Rough Surfaces | UV and Weather Resistant | 14Ft Heavy Duty Roll
    One thing's for sure, this stuff is sticky - which is the whole point! Two long strips, one across the top and one on the bottom, these panels should be set for quite a while.
    The door cards came from Factory Five with the 25th Anniversary stitching, but the panels were in horrible shape from FFR.
    Sadly, they didn't do anything about it, so when I had my transmission tunnel and stereo box wrapped, the guys at Fine Line Trim in Rancho Cordova, CA did a solid for me and rebuild the door cards for free!
    You can see the panels with two long strips of velcro attached. I pressed pretty hard to ensure the tape adhered, and once it's attached, it's really on there!
    Time to say goodbye to those beautiful San Marino Blue painted doors, and add the new door cards. I think the new door cards look awesome!
    Todd
  64. Likes 460.465USMC, danmas liked this post
  65. #680
    Folsom, CA
    OK - this is a fun change, I submitted for a new California plate, even encouraged by my wife
    somewhat surprised it made it through IYKYK
    Todd
