54
81
Originally Posted by
MSumners
Is this regulator too low for othe gen 3 coyote, wondering if there may be interference?
Looking at mine just now, yes I should clear. By an inch or so. It may/may not clear when you tip the engine in though. Something to watch for. Curious why you have it that low. FWIW, I have mine in the same spot, but the adjuster on the regulator is roughly the same height as the footbox top. Makes things easy to get to and the fuel line over to the engine is a relatively straight.
Build Thread and
Video.
Build Thread.
Build 5: 35 Hot Rod Truck #138.
Build Thread. Sold 11/9/2023.
Build 6: Mk5 Roadster 30th Anniversary #11,258.
Build Thread.
