I installed a Ford Racing 392 stroker with a double sump and have +/- 1/8" or slightly less clearance. During the engine install, until the xmission (Tremec TKO) was set in place with appropiate spacers, I had interference. The Ford Racing oil pan maybe an option. I do not have power steering but understand this oil pan may cause problems if power steering is desired. I've got about 50 miles and believe me you may want power steering.
Chuck (The junior member one)
