Results 1 to 13 of 13
Thread: Ultra Thermostat Housing Assembly. Now in Stock
    Banned
    Hi Everyone.
    We finally have back in stock the "Ultra Thermostat Housings. See here for more details - https://tdmotion.com/product/427w-fo...t-housing-kit/
    Can purchase the lower Housing or full kit with the lower and upper housing with Hardware, stat, gasket, Radiator cap etc.
    Small Block Fords are notorious for trapping air in the cooling system which leads to “Hot Spots” in the cooling System. Most of the Cobras and Coupes radiators sit higher than the thermostat housings
    This filler neck kit allows the system to be filled from the intake manifold to remove air pockets.
    561-427-8285
    TD Motion Inc.
    Banned
    After selling out first batch, just got more of the billet thermostat Housings in stock.
    Sep 2022
    Oooh...yeah
    We saw these in the build class...engine jewelry
    Craig C
    St. Louis, MO
    I get a 404 error for this link.
    Jan 2019
    Mead Colorado
    Quote Originally Posted by MPTech View Post
    Top link works:
    Current BOM and Build Thread
    Aug 2021
    El Dorado Hills, CA
    $500? Yikes! But it is pretty
  7. Likes cc2Arider liked this post
    Dec 2021
    Flower Mound TX
    I see gaskets. Why go to all that trouble and not use O-rings? Just saying.
    Jul 2022
    Ventura County, CA
    The website shows a picture of my engine using a discontinued CobraEarl unit, not the one being sold today!
  10. #9
    Oct 2023
    Managed to tweak price $20 on our Ultra Thermostat Housing Assemblies.......
  11. #10
    Oct 2023
  12. #11
    May 2013
    OH,KY,WV tri-state area
    Quote Originally Posted by Ted G View Post
    I see that as unneeded. Just drill a 1/8th hole in the body of a thermostat and it will burp air out without the BIG bill.
  13. #12
    Well Used Member
    So. Bay (So. Calif.)
    Just an FYI. I have it since the engine was built. I like the looks and the functionality. I'm happy with it, and would definitely do it again.
  14. #13
    I had one of those on my Dart 347 #7750 Roadster build. Worked great and solved several issues with the stock setup. Was also from CobraEarl. $105 10 years ago including shipping. Checked my records. Some change. Also before I found out it wasn't cool to use the corrugated hoses.
