Can purchase the lower Housing or full kit with the lower and upper housing with Hardware, stat, gasket, Radiator cap etc.
Small Block Fords are notorious for trapping air in the cooling system which leads to “Hot Spots” in the cooling System. Most of the Cobras and Coupes radiators sit higher than the thermostat housings
This filler neck kit allows the system to be filled from the intake manifold to remove air pockets.
561-427-8285
TD Motion Inc.
Just an FYI. I have it since the engine was built. I like the looks and the functionality. I'm happy with it, and would definitely do it again.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
I had one of those on my Dart 347 #7750 Roadster build. Worked great and solved several issues with the stock setup. Was also from CobraEarl. $105 10 years ago including shipping. Checked my records. Some change. Also before I found out it wasn't cool to use the corrugated hoses.
