Thanks Thanks:  6
Likes Likes:  2
Results 1 to 18 of 18
Thread: CAUTION power steering pump pressure
    Mar 2018
    Saint Johns, Florida
    Exclamation CAUTION power steering pump pressure
    Hi there,
    There has been some posts about mounting various power steering pumps to a SBF. Be aware that the Mustang II power steering rack likes less than 800psi pressure; spec max is 1000. GM pumps (and others) put out too much pressure and need to be modified to prevent blowing up the rack; or use a Heidts proportioning valve to reduce pressure and give more steering feel. Check internet for pressure reducing methods.
    Enjoy,
    Mk4 Complete kit with IRS, IRS brakes, Power Steering, 302 mounts, 302 headers, TKO, 2 Rollbars, Leather seats,
    vintage gauges, polished stainless sidepipes, front and rear sway bars, all cutouts.
    Blueprint Engines 347 stroker; Tremec TKO 600; 3.55 IRS, 17" Bullitt wheels: 9" front 10.5" rear.
    Delivered Nov. 6, 2018. First start Aug. 11, 2019. First Go-Cart Feb. 21, 2020.
  2. Thanks MPTech thanked for this post
    Mar 2018
    Cool Which power steering pump?
    Quote Originally Posted by Jeff's First FFR View Post
    Hi there,
    Enjoy,
    For me I chose a 1965 Mustang power steering pump because of its pressure (800-850psi) and cost ($100-150); even available in chrome for an up charge. Even with its low pressure the steering was too light for me so I added the Heidts adjustable valve...perfect! I have the CVF V-belt FEAD with the Bronco PS bracket and everything fits.
    Oct 2020
    Albany, NY
    I have a GM Saginaw style pump because I t’s looks awesome. I used a restrictor to drop it to 650 psi. It handles beautifully.
    Build 1 MK4 #10008 - Delivered 03/03/21, Graduated 7/20/22 - Sold 6/6/24 Build Thread #1 https://shorturl.at/K9fuy
    Build 2 MK4 #11061- Delivered 08/24/24 Build Thread #2 https://shorturl.at/OZowi
    Build 3 35 Pickup #329 - Delivered 10/28/25 Build Thread #3 https://shorturl.at/Ty4QQ
  5. Thanks GoDadGo thanked for this post
  6. #4
    Jun 2012
    New Brunswick, Canada
    Can you tell us more about the restrictor you used?
  7. #5
    Oct 2020
    Albany, NY
    Sure, this is the PS pump I used.
    https://www.cvfracing.com/saginaw-p-...y-shaft-black/
    CVF racing sells an 800 psi reducer as well (link below) I used one very similar. I just tried to find it and it does not seem to be available from where I got it.
    https://www.cvfracing.com/saginaw-p-...valve-800-psi/
    Now they are selling this instead. I have no experience with this setup but it gets solid reviews.
    https://www.borgeson.com/Pumps-Brack...cing-Shim-Kit/
  8. Thanks Jonathan D, GoDadGo thanked for this post
    Likes Jonathan D liked this post
  9. #6
    Edmonton, Alberta
    What did you use for a mount?
    Mk III 4880: 3:55 - 3 link, T-5, 347, Holley Sniper/dual sync distributor, Comp Cams XE274HR, Edelbrock RPM Heads
  10. #7
    Oct 2020
    Albany, NY
  11. Thanks Geoff H, GoDadGo thanked for this post
  12. #8
    Jun 2012
    Great share, I had never seen this kit and I was poking around on their site a couple of times!
  13. #9
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    Why you need to adjust the power steering pressure
    This is why you want to reduce the power steering pump pressure
    I was out on the track at Indy and the engine was seeing about 6G rpms and just as I was finishing my session out on the track the steering got really hard to steer. I missed my pull in off the track so fought with the steering wheel to get back to the pit pull in. There was the director asking me to pull over. He had me stopped there for a few minutes then asked didn't you see the flag. Yup I saw the flag and if you would let me through I can get the car into the pits before it dumps the power steering fluid all over your shoes. By then I began to know what had happened. Red fluid was dropping on his shoes. then he looked down and said you can go now...
    The pressure blew the hose right out of the rack! Notice the left - there are NO threads to install the power steering hose!!
    He had walked right up close to the front of the car. I think was trying to "make a point"!
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
  14. #10
    St. Louis, MO
    Very timely post for me, just installed the Saginaw setup on mine, but haven't started it yet.
    How does this CVF Pressure Reducing Valve install? (On the pump output port?)
  15. #11
    Oct 2020
    Albany, NY
    Yes, that's right.
  16. #12
    We've used this part when we've stuffed Small Block Chevy's into Fox Body & Later Mustangs.
    https://www.jegs.com/i/JEGS/555/60791/10002/-1
    They work just fine; however, I felt like they still over boosted the system but these cars had skinny front tires since they were primarily 1/4 milers instead of corner carvers. All ran skinny front tires that were 215's or smaller widths.
  17. Likes Geoff H liked this post
  18. #13
    I wish we would have known about these solutions specifically modified for Ford Racks!
  19. #14
    St. Louis, MO
    Will this Saginaw Power Steering Pressure Reducer fitting work? (Jegs is out of stock until end of Sept).
    Just double checking, this replaces the current output fitting (remove old and install this unit). Wish I had known this before I bought the 6AN adapter, could have done it with 1 fitting.
    https://www.summitracing.com/parts/pfn-sf23
    Thanks for the heads up @Jeff's First FFR
  20. #15
    Oct 2020
    Albany, NY
    This is almost identical to what I used. I never thought to look at summit for some reason.
    https://www.summitracing.com/parts/clp-cpfcv-k
    The one you have listed seems to be the same thing in a one piece form. I used the 2 fitting setup.
    Edit***
    Actually I think I found the one I purchased.
    https://www.ebay.com/itm/26468332665...mis&media=COPY
  21. #16
    O'Fallon, MO
    Why are you using a Mustang II power steering rack? These cars are designed to use a Fox body Mustang or later rack. The stock Ford pump makes between 1200-1500#'s of pressure
  22. #17
    Oct 2020
    Albany, NY
    I’m not but the steering is over twitchy with the Saginaw and Fox rack as well. The reducer improved it.
  23. #18
    Dec 2020
    Layton Utah
    You can also pick up a Saginaw pump that has the lower pressure and skip the reducer.
    I did the Tuff Stuff 6174B, it has reduced psi for the Mustang II racks.
