Quote Originally Posted by toadster View Post
finally getting this intake installed on the car, the breather tube seems too short to reach the elbow (haven't drilled for the bung yet)
each section is pushed into the tubing till it stops so can't go any shorter
do I need a longer PCV hose?
Likely, yes. I did mine exactly as Edwardb shows in his photo above. Just cut that hose off and re-use the fittings with some Gates PCV-rated hose.
