Thanks Thanks:  4
Likes Likes:  6
Results 1 to 22 of 22
Thread: spectre intake Coyote Gen3 - where does the breather hose go?
    Folsom, CA
    From prior knowledge, you can use the Spectre or Treadstone intakes - I got the Spectre from Mike Forte as part of my Coyote Gen3 setup
    there are no Spectre instructions on the Gen3 installation guide, so I had to check the prior guide
    https://www.factoryfive.com/wp-conte...ter-rev-2B.pdf
    from Gen3 install guide https://www.factoryfive.com/wp-conte...ter-rev-1F.pdf
    there is no chrome elbow shown with the 'port' for the intake tube (see above pic)
    my question is - where does the breather hose connect? or is it not needed?
    Todd
    Nov 2018
    Centennial, CO
    On my gen 2 it connects though the left side coil cover.
    Also, those two ports on the elbow had to be drilled out on mine.
    Bradley
    Folsom, CA
    No hole in my 90 degree bend
    Todd
    Folsom, CA
    Quote Originally Posted by GTBradley View Post
    do you have instructions??
    Todd
    Aug 2021
    Moyock, NC (OBX/Hampton Roads)
    The second picture on page 73 of the coyote guide you linked shows where the other end goes. thats just a fresh air intake, so some people do not hook it up to the intake and instead just put a little filter on it. Something like this: https://lmr.com/item/LRS-261340JR/mu...ather-kit-1116 Goes on the port on the drivers side of the valve cover.
    MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
    Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
    Folsom, CA
    Quote Originally Posted by JeffP View Post
    p73 shows the engine side of the hose connecting to the intake
    im not sure an open breather will pass CA smog
    Todd
    Nov 2018
    Centennial, CO
    The kit I received had both the rubber elbow and the polished one. Only the rubber one had ports, so I used a step drill to make the holes and used blue RTV to seal the adapters in place. The instructions on mine don’t mention anything about modifying the polished elbow but the pictures do show it with the ports installed in the adapter between the elbow and the throttle body. I believe the intake and associated part kit came from JLT. The ports are for CMVV and PCV.
    Sorry I can’t be of more help on the instructions, but the above picture shows where I mounted mine. Hopefully, it’s the same on a gen3.
    FYI, I did eventually clock the MAF to the nine o’clock position.
    Bradley
    Later version Gen 2's and all Gen 3's don't have a CMCV connection to the intake. They use ambient air by the vacuum motors with no work required. Only connection is the PCV.
  9. Likes toadster liked this post
  10. #9
    Folsom, CA
    yes that’s my concern - there is no PCV connection on the 90-degree bend - do I have an incorrect part?
    Todd
  11. #10
    Quote Originally Posted by toadster View Post
    I'm not aware the Spectre piece ever came with a PCV connection. Mine didn't. No worries. Just add one. I bought the connector from JLT. Same type as the other Coyote connectors. Maybe available elsewhere, but that's where I found them. Comes with a grommet so cut the hole accordingly. The lower connection in this picture from my 20th Anniversary Roadster. This was an early Gen 2 so also had a CMCV connection. Ignore for later Gen 2's and the Gen 3.
  12. #11
    Folsom, CA
    Thanks guys - I'm really surprised, actually shouldn't be at this point, that this is one of those things that is 1/2 provided for in the kit - if they source the PCV tube, they should source the other end of the connection.
    For a $150 intake you'd think they'd add the connector - or even instructions!
    Todd
  13. #12
    Folsom, CA
    Todd
  14. #13
    Apr 2020
    Toadster, I cut the fittings out of the F5 provided intake, then drilled the spectre part and had them welded in. After my gen3 started running poorly I machined new fittings and remounted the rubber F5 part. Now it won't start with either one. Quite disappointed with the intake/ecu support/info. Hope you have better outcome.
  15. #14
    Quote Originally Posted by Andrew Davis View Post
    Something else is happening here. The PCV line from the LH head to the intake (the subject of this thread) alone shouldn't affect running and especially not cause a no-start condition. It's an emissions thing and typically recommended to have connected. But guys run them open at the head connection (e.g. with a filter only) and the engine starts and runs normally.
    Have you had your Gen 3 custom tuned? It's not going to run well until then. But it should still start.
  16. Thanks Andrew Davis thanked for this post
    Likes Andrew Davis liked this post
  17. #15
    Folsom, CA
    I'd agree with Paul on this one, the PCV return won't create a run issue, it's an emissions item
    I'm not a big fan of how 'deep' this port runs in the intake, I may trim it down quite a bit seems like it would block airflow
    Todd
  18. Thanks Andrew Davis thanked for this post
  19. #16
    Folsom, CA
    finally getting this intake installed on the car, the breather tube seems too short to reach the elbow (haven't drilled for the bung yet)
    each section is pushed into the tubing till it stops so can't go any shorter
    do I need a longer PCV hose?
    Todd
  20. #17
    Sep 2018
    SF Bay Area, CA
    Likely, yes. I did mine exactly as Edwardb shows in his photo above. Just cut that hose off and re-use the fittings with some Gates PCV-rated hose.
  21. #18
    Folsom, CA
    Quote Originally Posted by JohnK View Post
    ah makes sense! I wish FFR would document these things! I guess with their intake hose it just fits, but anyone with a Spectre setup will need to modify...
    I've lost track of how many modifications are needed on this car! LOL
    Todd
  22. #19
    Aug 2019
    Verona ILL
    You may be able to heat that tube with a heat gun and form it to fit. Did this on my Gen 3. I started with the plastic fitting in the rubber grommet and ended up with a new elbow with an aluminum fitting I welded into the elbow. Worked out well. Sorry no pic of just the elbow with fitting.
    Mk4 9735 complete kit delivered 11/29/19 Gen 3 Coyote, Tremec TKO 600, Moser 3.55 First start June 25, 2020 First Go Cart July 20, 2020
  23. Likes toadster liked this post
  24. #20
    Folsom, CA
    Quote Originally Posted by Jryasko View Post
    that's a good idea, it's a very odd plastic tube for sure - almost heat shrink material... but too late, already trimmed it and looking for some spare hose
    Todd
  25. #21
    Sep 2018
    SF Bay Area, CA
    Todd - this is what I used:
    My Amazon purchase history says I bought 25' of it. I can go check in the garage tomorrow and if I can find it I'm happy to send you a few feet. We moved houses a few month ago, so no guarantees I'll find it.
  26. Thanks toadster thanked for this post
  27. #22
    Prescott, AZ
    I worked with Guy Smith at Spectre Performance to put together components that would fit and look the way I wanted to. As usual my solution was not a cheap way to go, but got what I wanted. A note, Spectre Performance is a K&N company.
    The intake tube is from a kit designed for the Mustang GT. About the only thing I was able to use was the intake tube. I went that route as I do not have anyone local that I would trust to do good aluminum tig welding. The intake tube has all the connections for the Coyote vacuum line and crankcase ventilation. A shorter 3.5 inch coupler was selected at the throttle body. I opted for a black HPR9617K air filter with a SPR-990003 MAF sleeve. The MAF sleeve adapts the 4" filter intake to the 3.5 inch intake tube. I choose the 9617 filter to maximize filter area and fill the space between the end of the intake tube and the inner fender apron.
    guy@spectreperformance.com
    See post #237 in my build thread on the Vintage Mustang Forum
    https://www.vintage-mustang.com/thre...#post-10516669
  28. Thanks toadster thanked for this post
