Thread: Dimmer Switch | GM Style | Changing to Push Button??
    Aug 2020
    All,
    Does anyone know if you can wire a GM dimmer high/low dimmer, foot controlled switch to a push button switch?
    Taking this switch:
    https://www.americanautowire.com/sho...er-switch-4390
    Turning it into a push button, you mount it on the dash, example:
    https://www.oreillyauto.com/detail/c...i0/84822?pos=0
    What on/off push button switch would work? How would you wire?
    Thoughts?
    Matt
    Sep 2018
    SF Bay Area, CA
    I'm planning to wire the momentary button on the end of the stalk of the RT turn signal as the high/low beam switch and flash-to-pass using this relay from Ididit. I would think (though can't confirm) that any momentary button would work similarly.
    Jul 2019
    Quote Originally Posted by JohnK View Post
    I'm using the IDIDIT also and it works great. And yes, a momentary button switch will work with the IDIDIT. All the switch does is key the relays.
    This will be a project for the winter (maybe) for me as well. I installed the Russ Thompson turn signal setup this year, and plan to move my foot-operated headlight dimmer to the button (momentary switch) on the stalk. I bought the ididit dimmer relay for this, which appears to be very hard to find right now. Summit Racing has two options available:
    https://www.summitracing.com/parts/i...IaAvbwEALw_wcB
    https://www.summitracing.com/parts/idt-3100030140
    Aug 2020
    This worked perfect:
    https://www.amazon.com/GAMA-Electron.../dp/B001PNIKEY
    High beam and light indicator get wired together…
    All on one side:
    Hot to the middle
    Low beam light to bottom
    High beam/high beam light indicator to top
    Hope this helps…
    I was unable to find a 30amp SPDT push button switch
    Nov 2016
    "The i.e." SoCal
    We went a new direction with the Russ Thompson switch on the end of the turn signal switch. Got tired of the inconsistency of the currently available latching relays and went with a latching switch instead.
    Sep 2018
    Charleston, SC
    do you have a link to the latching switch?
    F5R #10227 - Forte's 363 EFI, IRS
    Nov 2016
    "The i.e." SoCal
    Quote Originally Posted by ChasNMe View Post
    If you were asking me. Found them here.
    https://www.ebay.com/itm/30405718334...53.m2749.l2649
    Sep 2018
    Charleston, SC
    I was, thank you sir
