Thanks Thanks:  61
Likes Likes:  403
Page 23 of 27 FirstFirst ... 132122232425 ... LastLast
Results 881 to 920 of 1072
Thread: John's EZ36R H6 818R Build
  1. #881
    Mar 2021
    SE WI Kettle Moraine
    Sgt, your experience would obfuscate static pressure, there would be a reading but the source would be unknown. Dynamic pressure translates to air speed and direction. In either case the magnitude is small, inches of water. An instrument or data collector must have an appropriate (low pressure) range. I used Omegas that would register peak for testing at speed.
    jim
  2. #882
    Taping wool tufts at the entrance and exit and recording them with a GoPro may be very interesting.
    This is my video when I was testing a rear-mounted radiator. The fans on the radiator was running.
  3. Likes Sgt.Gator liked this post
  4. #883
    Here is another video of rear airflow.
  5. Likes Sgt.Gator liked this post
  6. #884
    Syracuse, NY
    Break-in at Watkins Glen
    This is kind of long so if you want the juicy stuff, skip to the pics
    So I've spent the last two days at Watkins Glen International breaking in the new motor, clutch etc...
    First the good parts:
    I got ~300 miles on the new motor and it ran perfectly. It's not tuned so it didn't make great power with only about 3.5 psi of boost, but from a mechanical perspective it could not have gone better. Starts and idles smoothly, BOV makes a cool woosh... sound when you shift or let off the throttle. Runs super smooth and revs quick thanks to the shorter stroke and balanced internals. I kept the revs under 5200 and throttle below 70% all while managing to get passed by everybody .... sometimes twice in a single session
    Temps and pressures were all good except the IAT's are a little higher than I would like at ~105 F. I will have to add some heat shielding and maybe work on my ducting a bit more.
    Oil consumption and blow by are nonexistent. After 300 miles, zero oil in the catch can. I must have gotten the ring gaps right.
    Now the bad parts:
    At the end of the second day I backed out of the garage and the car abruptly stopped. Kind of felt like a wheel chock was left behind my tire. I tried moving forward and the car would go about 3 feet and abruptly stop again. The car would only move 3 feet forward and back, no more.
    After some poking around myself and a few other determined it was something in the transaxle. Well that's something I can not fix at the track so my day was over. Hard part now was getting the car in the trailer! We ended up removing the under body panels at the rear and using two floor jacks to raise the rear tires off the ground and then winched the car into the trailer backwards.
    Fast forward to today:
    I drained the transaxale and metal chunks started falling into the bucket. Not a good sign I thought to myself, probably ate a ring and pinion gear set.
    After getting into the tear down I was shocked to discover that every single ring gear bolt was loose and most were sticking up. One of the the bolts was so far out it was digging into the sun dial and that was what was causing the car to stop. The inside of the case has some scars but nothing that will effect functionality once its cleaned up. I need to order new ring gear bolts, clean evenything thoughly and reassemble.
    All in all it could have been much worse. If one of those bolts came out, or a head broke off, it would have destroyed the transmission.
    As it is I'm only out some new bolts and my time. What do you think could have made this happen? I have my theories but I'd like to hear yours.
    MK3.1 Roadster completed 2011
    818R rebuild with a JDM Honda K24A completed 2023
  7. #885
    Apr 2021
    Possibly the ring gear was not seated when the bolts were torqued.
  8. Likes jforand liked this post
  9. #886
    Mine came loose while going 70 mph on the highway.
    Dumped all the oil down the middle lane.
    My transmission case had never been opened.
  10. #887
    Jan 2020
    This is not good news at all. It would be nice if they were a lot easier to get to for a re-torque.
  11. #888
    Syracuse, NY
    Quote Originally Posted by SnailFoot View Post
    Doubtful as this was a factory untouched unit.
    I count myself lucky as it could have been much worse.
    Quote Originally Posted by jforand View Post
    Yes, a complete tear down is the only way to get to them.
    Given the way that all the fasteners were loose about the same amount. This is most likely a vibration issue, operating near the resonate frequency of the assembly and that caused them to back out.
    I am considering either Nord-Lock washers if there is space and grip length on the bolts to accommodate them, or I'm going to try to drill the heads and use safety wire. The issue with drilling them is that they are thin external Torx heads with a large flange so not an easy thing to drill.
  12. #889
    Mar 2021
    John, I have heard it said that Loctite will not fix a defect, but I am interested to know if you found Loctite on the threads. Is thread locker speced by Subaru?
    Are these the original bolts? Have they or the assembly procedure been updated (TSB)? For instance has the bolt been redesigned with a necked-down shaft to provide more stretch at design torque? Short bolts do not stretch much.
    Is the gear tooth pattern consistent? Is there a "spot" anomaly that could set-up a vibration? Bearings OK?
    jim
  13. #890
    Bend, Oregon
    The answer is simple: Because Racecar.
    Something is vibrating. Do you have an aftermarket lightened flywheel?
    Owner: Colonel Red Racing
  14. #891
    Jan 2020
    Can you ‘stake’ or ‘peen’ the outside circumference of the flange to the ring gear flange? The idea is to make enough of a deformity that it will not easily rotate past. Ultimately the Nord-Lock washers need that dig into the ring gear flange (causing some deformity) so that the base washer does not rotate and then of course any rotation of the bolt head would bring the top masher with it and the inclined planes would prevent the loosening. Perhaps you could make a small dimple in the flange that you could stake a bit of the bolt flange down into. Putting a serious wrench on it would drive past the point without issue for removal.
  15. #892
    Mar 2021
    John,
    I reread your post and see "balanced internals" and "shorter stroke". My SBF and Mazda rotary had balanced flywheels. Any chance the short stroke is not compatible with the flywheel?
    That is a reach. I have a hard time connecting engine to this failure. How about the axles/CVs? Can a drive shaft shop spin them?
    jim
  16. #893
    Syracuse, NY
    jim
    Gear tooth pattern looks good and I have not looked at the bearing yet.
    In fact I do have an Exedy lightened flywheel that I just added last year ... hmm....
    John,
    jim
    I don't think so as the flywheel has a neutral balance. Boxer engines are internally balanced and do not require any external weighting like most american V8's do.
  17. #894
    Syracuse, NY
    Here is a look at the inside of the case where the ring bolt was contacting around the sundial area. You can clearly see the two large burs built up that was causing the abrupt stop in the forward and rearward motion of the car. Glad I was being gentle with the car and didn't just "put the beans to it" in order to get it to move
    Here are some of the aluminum bits from the trans oil.
    My solution to the ring gear bolt issue is to drill the bolt heads and use safety wire to keep them from backing off. A few hours on the milling machine and I now have ring gear bolts with holes in one of the external torx lobes. First I used a small end mill to create a flat section on one side of the lobe. Then spotted the hole before drilling the 1/16" thru hole. I think I'm going to do it to the clutch cover bolts as well since its apart now.
  18. Likes DSR-3, Santiago, SnailFoot liked this post
  19. #895
    Apr 2021
    I found a forum post about this and how one person handles the problem. https://forums.nasioc.com/forums/sho...2831498&page=3 #59
    It looks like other people have had a similar problem with the ring gear coming loose.
  20. Thanks DSR-3 thanked for this post
  21. #896
    Dec 2018
    Just outside ABQ, NM
    Well, crap. Wishing I had done something about this when we had our transmission apart. Guess we’ll just cross our fingers for now.
  22. #897
    Syracuse, NY
    Safety wired the flywheel and clutch cover
    While I'm waiting for parts to come in from Subaru to reassemble my 6 speed, I decided to safety wire both the flywheel and clutch cover. Since the transmission is off anyway, might as well head off those potential issues now.
    I made a nice drill jig to make drilling all the bolts super fast and easy. I didn't even break a drill bit since the jig holds everything straight and tight.
  23. #898
    Jan 2020
    Looks great. I see you decided to go through the full bolt on the centerline. I was wondering how the safety wire was going to work on your ring gear bolts. It seems that might be a bit more tricky and will depend on where the holes end up once torqued. Are you thinking about revising the way you drill the ring gear bolts?
  24. #899
    Syracuse, NY
    Thanks for posting this. I did not know that 5MT ring gear bolts would work on a 6MT.
    I am going to use 5MT ring gear bolts as they are normal hex head and I can drill straight thru them.
  25. #900
    Syracuse, NY
    AWIC on the way
    I was not happy with the IAT's I was seeing during the break-in at Watkins Glen. Even though the engine was under medium load and speeds were 100+ mph, the IAT's were over 100 F. I could not think of a way to dramatically improve the cooling flow through the intercooler core without major alterations to the bodywork, which I do not want to do.
    So a trip to https://www.frozenboost.com got me all the major component I need. The car is now almost completely apart again. But, this should fix the problem and it will be done before VIR in June!
  26. #901
    Mar 2021
    John, What was the delta, ambient to IAT?
    What was the delta, intercooler IAT "in" to intercooler IAT "out"?
    What performance does the intercooler manufacturer predict? Maybe your results are within manufacturer expectations.
    The data above can be compared to AWIC. Every track event is a new day.
    jim
  27. #902
    Syracuse, NY
    jim
    The ambient air temp was ~75 F, so I was seeing a delta of 25-30 degrees which is not acceptable as once its tuned and I turn up the wick I will be generating more heat which would put the IAT's in the danger zone.
    I do not have a sensor pre-intercooler so no data for that.
    The manufacturer does not give predicted deltas because there are so many variables. Like most mid-engined cars, cooling an intercooler is a challenge without large bodywork modifications. I do not want to alter the body that much as I like the looks of it now.
  28. #903
    Mar 2021
    John, Intercooling is not an expertise for me. I had to look up AWIC when I saw it on this forum. My interpretation is it is water to core to intake charge for cooling. I anticipate that it is a stand alone system, not sharing engine coolant.
    So both intake systems are dependent on ambient air. The difference is ambient to core to intake charge is supplanted by ambient to core to water to core to intake charge.,
    The assumption is there is more temperature drop across a water cooled core. Still the AWIC system is dependent on ambient and heat soak of the independent cooling system. The system will start at ambient but will heat soak over time.
    Ambient is an infinite medium.
    In the end it is IAT delta across the (intercooler) core after system temperature stabilization.
    jim
    If you like the 818 styling, you mway not like mine. I have not given thought to the intercooler yet. Eventually I will be NA.staggered shims.jpgstaggered shims2.jpg
  29. Likes Frank818 liked this post
  30. #904
    Williamsburg VA
    Hey Hobby
    The past weekend at Summit Point I was seeing peak intake air temps around 150 degrees on my Cobb. It was a hot day of between 85-90 so that didn’t help. I have a water temp gauge on my heat exchanger and it was at 90 degrees before I even left the pits. I am sure I was seeing the peak temp at top speed of above 120 for this track with my turbo set to make 18 psi. On cooler days the temp is lower for sure but if you run it hard on a hot day even my huge heat exchanger cannot keep up with keeping the temps down. I don’t know what you got from Frozen Boost but if you got there normal single pass one inch thick heat exchanger you will find out real fast it can’t keep up. We will have to compare our setups at VIR and see who’s does a better job.
  31. #905
    Syracuse, NY
    Quote Originally Posted by taco20 View Post
    Hey Hobby
    Good information. With most people on the forum posting temps 10 - 15 degrees above ambient with their AWIC systems I thought 30 degrees above ambient with my air to air was way too high. Hope I didn't jump the gun
    And yes, I got the 1" thick radiator that's 24"x14"x1". It's the same size as my coolant radiator, just thinner. How long does yours take to heat up on track? Do you have an additional reservoir?
  32. #906
    Williamsburg VA
    Hey Hobby
    I attached some old pics I have of my reservoir when I first put it on. Plus I included a newer picture of my bigger heat exchanger. I had to go with a bigger radiator and heat exchanger to try to keep things cool. I even had to lower the front panels down to included the lower hole above the front spliter to get more air for the radiator.
  33. #907
    Syracuse, NY
    And that's how you secure a ring gear!
    Loctite 263 + Safety Wire
    5MT ring gear bolts finally came in. Drilling them was challenging. I broke 3 cobalt drill bits in three different bolts. Miraculously I was able to drill them from the opposite side and knock out the broken bits with a small punch.
  34. Likes SnailFoot, AZPete, Santiago liked this post
  35. #908
    Apr 2021
    Did you run both radiator lines on the passenger side and both intercooler lines on the drivers side to keep the radiator lines from heating the intercooler lines?
  36. #909
    Syracuse, NY
    I have not run the intercooler lines yet, but yes both coolant lines are on the passenger side and both intercooler lines will be on the drivers side.
  37. #910
    Mar 2021
    John,
    Years ago in a development shop I heard the suggestion of using retaining compound in extraordinary thread retention circumstances. I might have tried it myself. Interesting detail is the shear strength of 263 thread nlocker is 1305 PSI and tensile strength of 275 PSI. Loctite 680 (green) retaining compound has a shear strength of 4000 PSI, no tensile strength listed. It is considered permanent. I think I saw retaining compound listed earlier in this thread.
    Getting broken drill bits out as you did means you lead a charmed life.
  38. #911
    Syracuse, NY
    I have retaining compound but its general only for very close fitment object like bearing races in a housing or press fit items. Realatively loose fitting things like threads generally don't work well with retaining compounds.
    Your not kidding! I was amazed I got them out. When it happened 3 times I was sure I'd have to order new bolts and wait another week to finish.
  39. #912
    Mar 2021
    John, The "gap" has to be tight enough to be anaerobic. Applications are all over, and I have witnessed miracles. Loctite says:
    Loctite 680 retaining compound is a high strength, high viscosity room temperature curing adhesive used to join fitted cylindrical parts. It fixtures in 10 min and provides a shear strength of 4000 psi. Capable of filling diametral gaps up to 0.015 Inch (0.38 mm). - Loctite 680 is designed for the bonding of cylindrical fitting parts, particularly where low viscosity is required. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration.
    Intercooler topic: I have discussed 33 Rod overheating on another post and NAZ came up with a stunning cooling system analysis: https://www.enginebasics.com/Engine%...20Cooling.html
    The facts about flows and temperature drops are applicable to intercooling devices. Not a casual read.
    MY SW20 Series II MR2 has an upgraded turbo with a larger intercooler flush to the right side air inlet and it has a full size fan sucking on it. Putting a fan on your intercooler might work with your air ducting or position the intercooler as I described on my MR2. Again, IAT deltas in and out of the intercooler would be the metric.
  40. #913
    Syracuse, NY
    I thought about adding a sucker fan to the top of the intercooler but I only had a little over 1.5" from the top of the intercooler to the underside of the rear hatch so I could not fit any sizable fan on top and since the intercooler and duct were almost touching the top of the transmission there was no room to move it down either.
    That also played into my decision to go AWIC.
  41. #914
    Mar 2021
    John, Displaying his nether-fan to competitors did not discourage Jim Hall with the Chaparral. Then again his downfall was competitors complained that it sucked.
    I am partial to the Carrier roof top A/C look.
  42. #915
    Syracuse, NY
    When changing a belt involves removing the engine!
    I decided to change the pulley size on my supercharger before going to the dyno in preparation for the VIR track day at the end of this month. I had been running the largest pulley Rotrex makes, 110mm. I would like to say I did this intentionally to ensure the engine would not see high boost during break-in, but honestly I calculated the pulley size wrong during my initial setup .
    During break-in I saw only about 3.5 psi of boost @ 5000 rpm. I am now moving to a 90 mm pulley in hopes of generating around 12 psi @ 7200 rpm. At this pulley size the supercharger impeller will be spinning at 90k rpm when the engine is at redline .
    The engine in my car is so close to the firewall that you can not access the front of the motor in order to remove the serpentine belt. The only way to get to it is to remove the engine. Well that was not going to happen so I decided instead to cut two access panels in the firewall to give me access to the font of the motor.
    The small hole on the left allows me to pass a ratchet extension thru the firewall to access the supercharger pulley bolt. The large triangular hole gives me good access to the front of the motor, including the belt tensioner.
    I was not too worried about the holes since the FFR aluminum firewall goes over this and will cover everything up nicely.
    Tomorrow the new pulley arrives and I can finally get this thing back together!
  43. Likes Frank818, DSR-3 liked this post
  44. #916
    Awesome!
    I plan on fitting a solid FW like yours one day (I use a thick heat shield sheet at the moment), but I need 2 triangles, that one and the one behind the driver.
    I did leave just enough space to remove the serpentine belt though, but other maintenance is not possible and I need to remove the entire old rear FFR FW every single time, which is about once a week.
    Now, are you sure you calculated that 90mm right or will it be wrong again?
    And when are we going to know?
    From 3.5psi to 12psi, that is a huge difference in power!
  45. #917
    Bend, Oregon
    I think I would still put cover plates over the engine firewall to separate it from the gas tank. Something simple with Dzus fasteners or similar.
  46. #918
    Syracuse, NY
    AWIC install complete
    Finally got the last part I was waiting for to finish the AWIC install. Retrofitting an AWIC is much more time consuming than doing it when your building the car!
    The AWIC radiator sits nicely in front of the main coolant radiator. Both are sealed in on all sides to ensure all the air is forced through the cores. There are a few inches of air gap between the radiators to keep the hot coolant radiator away from the cooler AWIC radiator. The pump is mounted low in the nose compartment and the 3/4" heater hoses are routed down the driver's side pod. I installed temperature sensors in both the inlet and outlet of the AWIC radiator so I can log temperature deltas.
    IMG_20210606_121515366.jpg IMG_20210606_121531494.jpg IMG_20210607_142548462.jpg IMG_20210606_121546805.jpg
    The intercooler support bracket was quite challenging to make on the fly without CAD drawings. Odd shapes and crazy angles, but it turned out nice. I wanted to mount the intercooler to the engine/trans instead of securing it to the chassis. This way it moves with the motor and does not stress any of the connections, plus it's easier to remove the drive line this way.
    IMG_20210610_194252222.jpg IMG_20210610_194939431.jpg IMG_20210610_194421189.jpg IMG_20210610_195215142.jpg
  47. Likes blomb11, Santiago, Rob T, DSR-3, STiPWRD liked this post
  48. #919
    Woodruff, SC
    John: I ended up with a radiator cap fitting and an expansion tank in my AWIC loop. The level in the tank goes up a bit when running and the water gets "hot". It might be overkill, but hasn't caused me any issues, either.
  49. #920
    Syracuse, NY
    Since the water should never get near boiling my thought is it should be ok without an overflow tank. I'll see how it goes.
