Quote Originally Posted by RBachman View Post
I got mine from Mike Forte' to replace a FiTech. Holley is much better. If you are military, or prior military I believe that Holley offers a discount, but you need to call Holley to ask. Holley also has discounted reconditioned units at a good price that come with the same warranty and they include all new wiring with it.
All,
Called https://www.efisystempro.com/sniper and got squared away:
Going all Sniper:
SNIPER EFI HYPERSPARK DISTRIBUTOR - FORD SMALL BLOCK (260/289/302)
Sniper EFI Hyperspark for 8.2" SBF Hi-Ram Manifold
PART# 565-322 -- Holley has the gear incorrectly labeled on their site...this part comes with a steel gear not a cast (in the part instructions it lists out -- * 565-322 comes with a hardened steel distributor gear)
PART# 556-151 -- Ignition Box
PART# 556-152 -- Ignition Coil
PART# 550-510 -- EFI Throttle Body
Hope this helps...
Matt
