0
4
If you want vacuum advance, get a 1985 mustang dizzy. They come with a steel gear compatible with a steel roller cam. And has a magnetic pickup. You can drop in a pertronix ignition module and off ya go. I run mine with a GM HEI module. I like that if i kill one ( which I have ) they are plentiful in any parts store.
Or.. get a full pertronix distributor.
If you plan to have the sniper do the ignition, I don't think you need a vacuum advance dizzy, but don't quote me on that. Then you can use almost any non TFI distributor. Just make sure it has a steel gear.
You have you coil sorted out? If you go with a pertronix , or HEI ignition, you can run a low Resistance R-Votr mustang coil. No need for a ballast resistor.
