JB in NOVA thanked for this post
toadster liked this post
Make sure you run the string parallel to the frame, not the rear tires as they can be slightly off, making your measurements at the fronts way off. I tried skimming a line to barely touch the front and rear of the rear tires only to find out that my solid rear axle is a degree or so off 90*from the thrust line, making my distances from the string to my fronts off by an inch from side to side.
I received a replacement Sniper EFI from Blueprint. Blueprint was really great to work with, and they sent the replacement Sniper right away.
Papa is right, replacing the Sniper wasn’t hard at all. First, I disconnected all the electrical leads, the fuel hoses, and vacuum hoses:
Next, I disconnected the accelerator throttle linkage. Then I unbolted the Sniper unit from the four studs on top of the engine:
After that, it comes right off:
I reinstalled the new one in reverse order, reconnected everything, crossed my fingers, and cranked the engine. Success! It started right up, and more importantly, my handheld unit showed the correct coolant temperature:
The idle was a bit fast, so I adjusted the idle set screw a bit, and it dialed right into the target idle speed of 900 rpm.
After that, there was nothing left to do but take it for a test drive! Here she is ready to launch:
And here’s her maiden voyage around the neighborhood:
Nice! Congrats.
Very good. I'm glad you have solved this issue. I am surprised as to how many Holley Sniper TB units need replacing. I've seen quite a few. Mine has been fine, but it is good to know that Holley/Blue Print takes care of the issue.
congrats! nothing like the first go kart experience. I love the family that was congregating on the 2nd lap to see what was going on. your camera has a weird depth perception and I thought you were going to run into something multiple times![]()
That looks like fun! Seeing how Blueprint took care of the issues with your Sniper makes me glad I went with one of their engines for my build.
Congratulations! What a great day!
Mark IV Complete kit delivered 7/7/20
Blueprint 427 ordered 11/23/20
Congratulations on another major milestone! Engine sounds fantastic
Mk IV Roadster #9749, Kit received Jan 2, 2020, Blueprint SBF 347 TKO600 Holley Sniper EFI, Dual roll bars, IRS, 17" Halibrand, Nitto 555 G2 245, 315 Road legal Oct 20, 2020
Congrats and great video!
MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start 11/28/20 l First Go-kart 4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l Build Thread
Congratulations.. That is always a exciting milestone.
Great video and good deal that Blue Print took care of your problem.
JR
Very cool, JB! Great success and getting all of the details right!
congrats. I know that was a fun ride!
Just watched you go-kart vid again, engine sounds so healthy and ready to rip!looking forward to seeing your car completed.
Sounds fantastic, and thanks for taking all the rest of us along for the ride!
Hey JB. Just wanted to say thank you. I am a week into my build and I have already corrected some " gotchas" that you documented very well including those irritating brake anti chatter clips and shims for the brake caliper mounting bracket on the passenger side. Also I mocked up my reservoir bracket and used your helpful link. just wanted you to know I appreciate your documentation![]()
JB in NOVA liked this post
Well, things have been very busy at work since early November, but I finally had time this week to get back to the Roadster project. I decided to carpet the trunk before putting the body on. Following the advice of many on this forum, I used a non-backed, light-weight trunk liner, which I purchased here: https://jjsupply.com/collections/tru...nkliner-carpet
I believe this is the same material that is used for speaker boxes, etc., but it works well as a trunk liner. First, I inserted rivnuts to hold the fuel-tank access panels:
Then, using 3M Super 77 spray adhesive (https://www.amazon.com/gp/product/B01MFA2EEE), I carpeted the trunk area:
And the cubby area:
I’m generally happy with how it turned out, especially considering that most imperfections will be hidden once the body is on. A couple lessons learned:
1. the spray adhesive tends to get everywhere, and it does not dry “clear” – it dries with a milky white color. So be sure to mask areas that you don’t want to get sprayed.
2. Do not attempt to drill a hole through sheet metal once the carpet is glued on. The drill bit will grab and twirl the carpet, essentially ruining it. Don’t ask how I know.![]()
rthomas98, I bought this rivnut/nutsert tool on amazon, which came with a bunch of rivnuts in different sizes: https://www.amazon.com/gp/product/B07BVMBP5P. It is metric, which isn't a particular problem if you have a good hardware store nearby with a good selection of metric machine screws. But in retrospect, I wish I had bought an SAE tool like this one: https://www.amazon.com/Performance-T...dp/B01M08ERVF/
Anyway, for my trunk panels, I used the M5 rivnuts, and they worked fine. I have had no problem with the aluminum buckling. Before I started using the tool, I tested it several times on scrap aluminum until I got the hang of it. Since then, I've had no problems with it at all.
Good luck!
Jrcuz, I don't remember precisely how much I ordered, but I'm pretty sure it was 5 yards. That was enough to do the entire trunk (including the Breeze drop trunk mod) and cubby area with some left over. The material is not terribly expensive ($6.25 per yard), so maybe order a bit extra if you're unsure. Good luck!
jrcuz thanked for this post
Looks awesome! Thanks for the great detail.
Hi JB,
Thanks for sharing what you used for the trunk carpet. I haven't yet run across the forum carpet advice you mentioned. Is there an issue with the supplied trunk carpet, so that's why you bought other carpet? Sorry for the dumb question, but just wanted to make sure I understand any carpet issues I may encounter. Thanks!
Chris, I honestly hadn't even noticed that my kit included trunk carpeting (so, certainly not a dumb question on your part). But I just checked, and you're right -- it does (not sure that was the case with older kits). Anyway, with my drop trunk mod, cubby mod, and the addition of extended interior trunk sidewalls, I'm not sure the FFR carpeting would have worked for me. But I think it would be a good idea to test fit the FFR-supplied carpeting to see if it will work for you. I will say, though, that the thinner trunk-lining material has a different look and feel than the thicker FFR carpeting, so that's another thing to consider. Just a matter of personal preference.
460.465USMC thanked for this post
JB, if you're interested in selling your trunk carpeting I'd be interested. I'm in no hurry to to do the trunk since the body is on right now.
Thanks, JR
After some much needed R&R with the family, I’m finally getting back to the Roadster project. At this point, I’m trying to take care of various odds and ends before I test fit the body. First, I closed up the hole for the shifter in the tunnel top. I found the FFR-supplied plate did not quite fit for some reason, so I fashioned my own and attached with rivets:
I know from others’ threads that these rivets might be problematic if I decide to cover the tunnel with leather, so I’m leaving the top unattached at this point in case I decide to replace the whole thing with a FFMetal version. Of course, that would require me to actually make a decision about color and trim, which I seem totally incapable of doing:
I thought building a car was hard -- choosing exterior and interior colors is impossible!!
Next, I installed the driver’s side exterior footbox panel, pre-insulating it before riveting it on:
I’m going to leave the top pieces unattached until after I test fit the body. Incidentally, the Swiss-cheese look at the bottom of the panel is the result of me pre-drilling holes 8 months ago without realizing that the bottom of the panel tucks inside the floor pan, where those holes are hidden and inaccessible. I created new holes once everything was mated up properly. Not a huge deal, but still a learning experience.
The only other thing I've managed to do is take care of an annoying drip from my coolant reservoir. No amount of tightening the threaded ports at the bottom seemed to be doing the trick, so I removed the reservoir, put it a vice, and tightened the inlet and drain ports with a bit more leverage. Incidentally, I found it helpful to use two pieces of wood on either side of the oval boss at the bottom of the reservoir to hold it in place without scratching the chrome finish:
This did the trick – no more coolant drips on my garage floor!
Looks great JB. I initially covered my tunnel top with the same felt/vinyl I covered my dash with then the plate and rivets showed up. I went with the FFMetal piece. I haven't covered it with the felt/vinyl yet having just finished cutting the holes for the shifter, cup holders and seat heater switches.
JR
My focus this weekend was getting the body prepped and test-fitted on the chassis. First, I flipped the body over and did a light sanding with a 60-grit block to knock off loose molding residue and strings. I also rounded all the sharp edges to minimize damage to the bulb seal. I vacuumed and wiped everything down with acetone. Then I masked the edges and applied two coats of bedliner (three in the wheel wells). I used this product:
This product is very thick and lumpy. The instructions say to stir with a paint stick, but I ended up using a drill-powered paint stirrer. Otherwise, the application was fairly straight-forward. A gallon was much more than I needed. Here is the result:
Because the fiberglass is textured, I did notice a bit of bleed through under the tape, so make sure to leave a good gap if you want to keep the bedliner away from the edges (which I understand is important for body prep and painting):
Next, I pressed bulb seal onto the firewall, trunk sides and rear floor, and the lower portions of the rear bulkhead wall, and covered everything with plastic to avoid scraping:
Finally, with the help of my wife and daughter and a friend, we got the body onto the chassis. I lined it up with the front and rear quick jacks and tightened everything down. The fit looks okay, although I will have to make a few adjustments before the final fit. The location of the horn interfered with the mounting bracket for the left, front quick jack, so that will have to be moved back an inch or so. Also, it looks like I need to cut back some of the bulb seal on the shoulders of the rear cockpit wall to get the rear of the body to sit down a fraction of an inch more. But otherwise, the fit was pretty good.
Here’s #9822 with the body on for the first time in nine months:
Progress continues . . .
BadAsp427 liked this post
Looks good JB. I remember flipping mine over in my backyard. IO used the Duplicolor bed liner also. I don't know why I bought 1 gal. and 1 qt. and had quite a bit of the gal. left over. I'll PM you about your trunk carpet.
JR
Great progress, JB! I bet it was great to see it with the body on.
Congrats, Looking good and it always feels so good to stand back and look at a "CAR" vs the go-cart.
Looking good! Did you decide on a painter yet?
Fman liked this post
Looks great, JB.
Sent you a PM
JR
Work has been insane for the past several weeks, but I finally got back in the garage this weekend. After test-fitting the body a few weeks ago, I removed it and trimmed some areas to improve the fit. On the body, I removed about ¼ inch from the front and rear lips of the cockpit:
On the chassis, I trimmed about 5/8” from the rear of the trunk floor so that the body could move forward a bit more.
Next, I completed the driver’s side footbox. I used rivnuts on the access panel, as many have suggested:
I relocated the horns (moved them back about an inch) because they had interfered with the bracket for the driver’s side quick jack. And I secured the wiring for the front PS lights to the bottom of the radiator shroud to keep it up and out of the way:
With all that done, I put the body back on this morning (with some help from my wife and son). And here she is again:
By the way, I am certainly glad I did the “Kleiner mod” for the rear quick jacks. From what I can tell, if you have a dropped trunk like I do, there is no other way to mount the rear quick jacks. Anyway, the mod worked perfectly for me. For the threaded portion, I used 7/16 x 6 inch threaded rods: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1, which seemed to work well:
Next I'll be tackling the hood, trunk, and doors . . .
jrcuz liked this post
Looks great JB, hope you got the PM I sent you. We got mine down to Whitby Motorcars this past Fri. now the wait begins.
JR
