Originally Posted by
Caddy Dad
I haven't adjusted the stock parameters that came with the engine when it was delivered. So the idle is set about 1000 RPM and I haven't touched the IAC screw. From what little I've read I'm thinking that maybe the idle ramp down time may need to be adjusted?
I'd recommend first simply running through the quick setup for setting the idle and see where that gets you. I'd target ~900rpm to start.
IDLE SETTING/THROTTLE PLATE SETTING
Once the engine is up to operating temperature (above 160° F), the idle speed can be set to what was configured in the Wizard.
To do this, open up the Initial Startup gauge screen. With the vehicle in neutral, adjust the idle screw until the IAC Position
reads between 2% and 10%. While adjusting the throttle plate screw, watch the TPS value and make sure it stays at 0%. While
adjusting the throttle plate screw, the TPS position may begin to read higher than 0%. If this happens cycling the ignition switch
will recalibrate the TPS back to zero.
NOTE: Do not attempt to set the target idle speed and IAC position until the engine is above 160°F!
