Thanks Thanks:  38
Likes Likes:  152
Page 10 of 12 FirstFirst ... 89101112 LastLast
Results 361 to 400 of 452
Thread: Carl's 20th Anniversary #8690 - Graduated... 15,000 miles
  1. #361
    I have considered one, but for some reason have not gone that route.
    Originally, I did not like the idea of not adjustable by lever.
    I might change my mind when I pull the seat and see what kind of hole alignment I am seeing.
    Thanks for the suggestion.
  2. #362
    Greeneville, TN
    Have you considered the Breeze seat mounts? The put the rear of the seat on the floor, the front elevated about 2", and give you about 3" of front to back adjustability. The front to back isn't slider "convenient", but allows you to reposition the seat without drilling new holes in the floor.
    That is where I got the idea of tilting the front. But I wasn’t gonna pay all of that money to do something I could do with literally three dollars worth of Hardware. I do not need to move my seat forward or backwards for any reason that I know of. So at the moment anyway I’m pretty happy with it.
  3. Likes Railroad liked this post
  4. #363
    Sep 2020
    Cary, NC
    BadAsp427,
    Thanks for putting together this build thread! Your speedy progress is inspirational.
    Regarding your chassis dolly, the 21" lift seems like it would be a convenient height to work at. This may be a dumb question, but how did you get the car off of the dolly when the time came for the first start?
  5. Likes BadAsp427 liked this post
  6. #364
    Greeneville, TN
    Quote Originally Posted by Rook View Post
    BadAsp427,
    Thanks for the comments...
    Do you really want to know the true balancing act that I went through? LOL.
    It was a combination of wood blocks under jack stands and floor jacks. It was a little bit of a hassle, but it was only one time.
    Just remember, if you build the dolly as I did, use wood glue and several 8" long lag bolts. Mine was solid as a rock when it was done.
    Carl
    Or maybe it was just my anti-gravity device I have in my garage.
  7. #365
    Sep 2020
    Cary, NC
    Haha, I figured that might be the case. Thanks for the reply!
    And let me know where I can get one of those anti-grav devices!
  8. #366
    Greeneville, TN
    At Jeff Kleiner's shop
    I had the opportunity to visit my build up in Bloomington IN today at Jeff's shop. He has completed a lot of work on it and while the body was off, I needed to do some minor work. Here are a couple photos of the build as it currently sits. Seeing all the work that Jeff had completed actually made me excited to see all the dust on everything, knowing it was only a few steps away from being beautiful. Shouldn't be long now and I'll be making the final decisions on color, stripes, etc. Exciting times.
    IMG_0409.jpg IMG_0415.jpg IMG_0408.jpg IMG_0414.jpg IMG_0416.jpg IMG_0417.jpg
    Thanks Jeff for taking the time to talk with me and allow me to work in your shop...
  9. Likes JB in NOVA, FF33rod, GWL liked this post
  10. #367
    You lucky rascal. I look forward to that day for me and my roadster. I too want to pick Jeff's mind on some things.
  11. #368
    New Braunfels, TX
    Carl,
    That’s awesome. I’m excited to see it all done!
    MK4-IRS, 427w, TKO-600
  12. #369
    Greeneville, TN
    Getting very close to having a completed paint job....
    It looks like only a week or two more before I will be able to show the world my completed and graduated 20th Anniversary Mk4. Based on my most recent conversation with Jeff on Oct 25th he said it would be about 10 days before he would have the final sealer/primer on and ready for color. I can only guess that I should be getting it around next weekend, November 13th or so. I'm not 100% sure yet... It's been a long patient 120+ day wait since it was dropped off on July 10th. Final colors have been selected and based on my last conversation Jeff should have the final sealer/primer on it by now.
    During that Oct 25 conversation, I asked Jeff to send me my Roll Bar beauty rings so that I could polish them up. He sent them right away and I did my thing and sent them back. Here are a couple before/after photos of those rings.
    This is a photo of the rings as they have been for the past 10,000 miles
    This is a photo of one polished, and one prior to polish
    Here are all 6 after polishing and just before returning them to Jeff for installation after paint.
  13. Likes JB in NOVA liked this post
  14. #370
    Those trim rings look good. Did you put a clear coat on them, after polishing?
    I might look into that, before the car leaves for Jeff.
  15. #371
    Greeneville, TN
    No clear coat. Just polished them on the bench grinder/polish wheel. I figured the clear coat would not look as good. When are you thinking you will have your car to jeff?
  16. #372
    Jul 2019
    Long wait!
    I'm sure you're anxious to finally get it back home!
  17. #373
    Chantilly, VA
    Look forward to seeing the car in paint and nice work on those trim rings.
    MKIV Complete Kit #9494 l Delivered 1/5/19 l First Start 11/28/20 l First Go-kart 4/11/21 l Carb'd 347 l Mid-shift TKO600 l 3.55 IRS l P/S l Forte Mechanical Throttle Linkage l RT Turn Signal, Drop Trunk l Breeze Upper/Lower Radiator Support, Fan Shroud l Boig Upper/Lower Cool Tubes & Quiet Pipes l 18" FFR Gasser Wheels l Build Thread
  18. #374
    I am optimistically looking at late winter.
    I plan on hauling up there on an open trailer, getting a couple of new spare tires and gathering up all the trim pieces.
    Undecided on how to get it home.
    Thanks for the reply.
  19. #375
    Greeneville, TN
    At last.... some photos of the car nearing paint completion...
    Today, Jeff K was able to get his camera over to the office to upload some photos of the work he has completed over the past 4 months. Looks like he will have some paint on it in the next week or so. Fingers crossed, Thanksgiving completion. I may be a little optimistic on that timing, (not the first time) but one can hope.
    carl12.jpgcarl13.jpgcarl14.jpgcarl16.jpgcarl17.jpgcarl18.jpgcarl22.jpgcarl26.jpgcarl28.jpg
    One of the challenges that Jeff encountered was some issues with the fiberglass not being done properly and having "blowouts" along the door jams. Here is one of the photos he sent me of this problem before he did his repairs.
  20. #376
    It's gray -- getting close now!
  21. #377
    Looking good Carl. Won't be long for color now!!
  22. #378
    Moving right along. Update me on your color choice.
  23. #379
    Greeneville, TN
    Carmine red, pewter gray metallic stripe with black pin stripes and center stripe. Similar to this, but better.
  24. #380
    Greeneville, TN
    Sneak Peak!!!
    Here is a sneak peak at my car. Close to finishing up the paint and body...
  25. Likes RBachman, Fman liked this post
  26. #381
    Dec 2018
    Hudsonville, MI
    Beautiful
    Coupe Kit Delivered 11/10/23
  27. Likes BadAsp427 liked this post
  28. #382
    Looking good Carl.
  29. Likes BadAsp427 liked this post
  30. #383
    Aug 2019
    Spokane, WA
    Nice, Carl. I really like your color choices and layout for center stripes!
  31. Likes BadAsp427 liked this post
  32. #384
    Kennebunkport, ME
    Oi! One tiny picture of the nose???
    Kyle
  33. #385
    BOY, that thing is slick.
  34. #386
    Greeneville, TN
    Long Awaited Photos of the Body Work
    Here are some photos that came in from the painter today.
    Here is the body with the Catalyzed Primer Surfacer after being dry sanded with 320 and wet sanded with 600
    This is the 2K Urethane Sealer Applied
    This is the Ford Raven Black applied for the pin and middle stripe
    This is the main stripes laid out.
    Here is the Gray Stripes painted. They are silver/gray, color matched to the FFR Halibrand wheels
    Here is the Masking off of all the stripes in preparation for the Porsche Carmine Red
    Here is the first photo of the Red after being laid down.
    Here are the first photos taken out in the natural daylight. It was overcast when these were taken.
  35. Likes Straversi, GTBradley, Fman, JB in NOVA liked this post
  36. #387
    Car is gorgeous! You are going to make me regret not painting mine red.
    Finish looks like it was dipped in pure gloss.
  37. #388
    Greeneville, TN
    I was actually just discussing it with the painter. He hasn’t even done the cut and buff on it yet.
  38. #389
    Chino Valley, Arizona
    Looks fantastic! Big fan of accent striping to the large stripes.
  39. #390
    Greeneville, TN
    Received some more photos from the painter
    Here are some progression shots... starting with the 1500 grit, 3000 grit and then the buffer... followed by some progression shots of the body going on to the chassis, the windshield going on, the hood, followed by the hood scoop and so on. Really starting to look like my vision. Can't wait to see how it looks with the final buff and in the sun.
    1500 Grit sanding
    3000 Grit Sanding
    After some time with the buffer and the headlights installed
    Body back down on the chassis and just about in place.
  40. Likes jrcuz, Fman, FF33rod, PeteMeindl liked this post
  41. #391
    Doesn't get much better than this for a Cobra build! Love the black accent stripe. Really fine job Carl!
  42. #392
    Dec 2018
    Hudsonville, MI
    Historically haven’t considered red but I love that color combination and the accent. Awesome.
  43. Likes BadAsp427 liked this post
  44. #393
    Looks great, Carl!
  45. Thanks BadAsp427 thanked for this post
  46. #394
    Greeneville, TN
    Wheel Knockoffs Polished and ready.
    As the day approches that I get to see my completed paint and body work I've been tinkering around. Tonight I was packing the trailer for the trip and thought, what the heck, let's polish up the wheel knockoffs and take them along so I can install them for the pickup photos. I would say I spent about 10 minutes with each one of them at the bench grinder with the polish wheel.
    Here is the before photo. And for the record, I thought they looked pretty good at this point.
    and here is an after photo taken in the exact same position and lighting.
    I found it really hard to take a photo of them and do them any justice so here are a couple photos that really show the mirror finish I was able to obtain. Notice the reflection of the towel and the Sharpy.
    And one last shot with a before/after together in the same photo
    And a couple more photos received from the painter today with the rear over riders in place and showing the inside of the trunk lid. Now I have to clean up that truck and finish it out. Still trying to decide exactly what I'm going to do there. Most likely just some simple short pile gray carpet with the aluminum cover plates over the top of it.
  47. #395
    Work of art with those interior stripes aligning with the outside. Can't wait to see it Carl!
  48. Thanks BadAsp427 thanked for this post
  49. #396
    Oct 2018
    Frankfort IL
    Carl,
    Looks great, it will be home in time to put it Under the Christmas tree
    Ed
  50. Thanks BadAsp427 thanked for this post
  51. #397
    Looks great. I really like how you did the stripes.
  52. Thanks BadAsp427 thanked for this post
  53. #398
    Greeneville, TN
    Picking it up and bringing it home 12-19-20
    This weekend will mark the end of a long 23 weeks. I'm getting my car back from the painter. I'll be making the drive up to Bloomington IN from South Carolina to load it up and bring it home. The paint and body work on it looks amazing. I've looked at all the photos I've posted on several different computer and phone screens and the Porsche Carmine Red looks different on all of them. I can not wait to see it in person. The plan is to also have Chad's (CV2065) car and mine side by side for some photo ops on Sunday... Chad's car is painted with the same color, but with different accents and stripes... Should be a great opportunity. More to come...
    The strip is actually a metallic gray that was color matched to the Halibrand wheels. The lighting on these photos do not do the stripes justice.
    and a photo of Chad's
  54. Likes FF33rod, Straversi, JB in NOVA liked this post
  55. #399
    Jun 2019
    Gurnee, IL
    Very cool Carl! Really like that color combo! Looking forward to the pics of both carmine reds' side by side.
    Build 1: MKIV #7275 Gen 2 Coyote TK600, IRS 3.55 2020 Graduated
    Build 2: Gen3 65 Coupe: Arrived June 2024. Gen 2 Coyote, T56, IRS 3.55
  56. #400
    Car is gorgeous. Congrats to you and Jeff.
