Still planning a Coyote, right? Then you won't use the clutch switch you just installed. The Coyote control pack comes with a clutch switch that matches the harness. In your Coyote completion kit, Factory Five has a mounting piece that goes on the clutch quadrant you just installed and the footbox. Then the Ford provided switch mounts to that. Check your Coyote installation instructions.
