My Coupe Build Thread: https://thefactoryfiveforum.com/show...65-Coupe-Build
My Roadster Build Thread: http://thefactoryfiveforum.com/showt...ter-Build-9754
I found your build thread and hope to learn a lot from it. Looks like your doing great. I'm about to make the plunge in to building one myself. Did you build the buck yourself? Did FF provide you plans for it?
Tom,
Thanks! The FFR manual includes plans for building the buck. You can order an electronic version of the manual from FFR for $10. It's worth having even with the printed manual as you can search it!
http://www.factoryfiveparts.com/1507...ital-copy-pdf/
Zach,
Get a countersink bit that will cut the same angle as the angle of the screw head. For the depth, I just set my drill press to stop at the desired depth. If you don't have a drill press, just do a little at a time and test the screw level until you get what you want. I started with pilot holes and then ran the countersink bit. Doing it that way, the bevel will be centered exactly where you want it.
ZachT thanked for this post
Very interesting to see the top installation. Looks like a quality kit.
Just found the perfect dash-cam on Amazon for your Roadster Dave
Very cool name! Another idea for my lisence plate.
Today I got a progress update from Jeff! He has what he calls the "dry work" done on my car, including knocking down the mold parting lines and finishing the wheel openings. Next will be the gaps and initial mud work. I'll post pictures as I get them, but I'm excited with what Jeff has told me.
BadAsp427 liked this post
I got some pictures today from Jeff. Body is 95% done with fitting and shaping. A couple days to cure, then the body will come off and the Slick Sand will go on. Getting closer to seeing some color!
Jealous, You Bet I Am!
Papa,
Saw your car today in person... coming along nicely
Dave, it is great seeing your car nearly finished. It provides some inspiration of what I hope mine will be one day. Your thread is one of the guides I have printed out to amend the FFR manual. I just got the body off last night and am starting the build process. Upper and lower control arms, here I come!
That is really exciting to see Dave.... It looks so plane with the shinny knocked off... LOL I'm getting excited because I know that mine will be there in the near future as well...
And somebody cut a hole in your hood??!!?!??
I’m so jealous! You gotta be just chomping at the bit.
Any rough ETA? Not that you want to rush a master artist....
Kurt
Build thread
Kurt,
No ETA and I'm not even asking. Jeff has been giving me periodic updates and we've chatted a few times since the car has been in his shop. I'm anxious to see it finished, but not to a point that I want Jeff to feel pressured to finish it. I already feel bad that Jeff has had to deal with a couple of other issues with the car. It fouled three plugs again. I'm not sure what is causing that, but will work on it once I get the car back. In the mean time, it means Jeff has to swap out the fouled plugs to get it to run right. Also, he's addressing my front end alignment. Where I had eyeballed it, the front wheels were too far forward and he's going to adjust it to closer to where it should be for me. When I get it back, I'll have the shop that the local Cobra club recommends dial it in. It will be done when it's done and I'm confident it will be everything I hoped it would be. Oh, and I'm glad I didn't have to cut the hole in the hood!
Yama-Bro liked this post
Excited for you Dave! I’ll have a week of vacation coming up where I’m going to have most everything buttoned up and ready to roll and get to where you are in the journey. I’m sure yours is going to look great!
Papa thanked for this post
Aircontroller liked this post
Serial #9158
Papa liked this post
Talked with Jeff and my car should be in Slick Sand Monday or Tuesday!
PeteMeindl liked this post
Nice!!!!!!
Build#1: MKIV Roadster #9320
Thats a great feeling, isnt it...
Boydster thanked for this post
Thank you very much. Looking forward to seeing some color on yours.
Well, I managed to find a way to spend a little more on my build even though the car is 1,100 miles away. Ever since I ordered my kit, I've wondered why I didn't buy the 18" Halibrands. The 17" wheels look great, but the 18" have that little extra cool factor with that fat rear lip. So, I ordered a set today. I'm looking at the BFGoodrich g-Force Rival S 1.5 Tires in a 245/40-18 front and 315/30-18 rear. Are there any better matching options that you guys are happy with? Once I get the car back and get the new shoes on, I'll be offering my 17" with Nitto 555 G2 tires for sale.
Dave,
I've been very happy so far with these... I have 8000 miles on them and really like the grip and the wear. Of course I'm not doing any kind of autocross to speak of and I do drive in the rain quite a lot. They really seem to have nice wet grip. Michelin Pilot Sport PS2 315/30R18 98 Y
I caved in on the 18' wheels during my order. That extra inch isn't cheap and I was attempting to be "frugal" to appease DW, but that lip is too sweet to pass up. Thankfully she approved once seeing the two side by side.
