Thanks Thanks:  259
Likes Likes:  576
Page 23 of 42 FirstFirst ... 13212223242533 ... LastLast
Results 881 to 920 of 1643
  1. #881
    Fun For For You Or Jeff?
    I'm sure you'll be extremely happy when you get the car back from Sir Jeff.
    I don't think either of us will be having much fun. Jeff gets to do all the work, and I have to endure the wait. No question I'll be happy with the car when it's done though.
  2. #882
    Quote Originally Posted by sethmark View Post
    This is the best build thread I’ve ever seen. My 12 year old daughter and I studied it so she could get an idea of the project in front of us. Thanks and congrats!
    Thanks for the kind words!
  3. #883
    Jun 2019
    I found your build thread and hope to learn a lot from it. Looks like your doing great. I'm about to make the plunge in to building one myself. Did you build the buck yourself? Did FF provide you plans for it?
  4. #884
    Quote Originally Posted by Tom Welch View Post
    Tom,
    Thanks! The FFR manual includes plans for building the buck. You can order an electronic version of the manual from FFR for $10. It's worth having even with the printed manual as you can search it!
    http://www.factoryfiveparts.com/1507...ital-copy-pdf/
    Apr 2015
    Grand Junction, CO
    Okay, I know my trunk panel isn't the most exciting thing I can be talking about, but here are the final pictures. I drilled and countersank the holes in the panel.
    When I attached it to the trunk, all but one screw went in clean. The fiberglass in the flange for the screw at the narrowest portion of the panel (bottom screw in the picture), didn't have anything to bite into.
    I'll just use a machine screw in that hole.
    Finally, I covered the two fuel tank access covers with carpet and replaced all the screws for the cover plates with black oxide button head screws.
    Other than getting the bulb seal on, the trunk is done. I will still need to drill for the back leg of the roll bars, but want to wait until they are permanently installed since I'm using the Tangent hidden bolts and don't know exactly where the tubing will bottom out on the main hoop.
    So Papa - how do you countersink the screw holes? I’m
    assuming that there is a countersinking drill bit that corresponds to the size of hardware that you’re using and that you run the bit all the way down and it countersinks as it bottoms out. Is that how it works?
  6. #886
    Zach,
    Get a countersink bit that will cut the same angle as the angle of the screw head. For the depth, I just set my drill press to stop at the desired depth. If you don't have a drill press, just do a little at a time and test the screw level until you get what you want. I started with pilot holes and then ran the countersink bit. Doing it that way, the bevel will be centered exactly where you want it.
  7. Thanks ZachT thanked for this post
  8. #887
    Apr 2015
    Grand Junction, CO
    Very interesting to see the top installation. Looks like a quality kit.
  9. #888
    Nov 2018
    Centennial, CO
    Just found the perfect dash-cam on Amazon for your Roadster Dave
    Bradley
  10. Likes BadAsp427, SSNK4US liked this post
  11. #889
    Very cool name! Another idea for my lisence plate.
    Today I got a progress update from Jeff! He has what he calls the "dry work" done on my car, including knocking down the mold parting lines and finishing the wheel openings. Next will be the gaps and initial mud work. I'll post pictures as I get them, but I'm excited with what Jeff has told me.
  13. Likes BadAsp427 liked this post
  14. #891
    Nov 2018
    Centennial, CO
    Progress! I like it! I think I'm in the same place, but no updates or pictures yet for me.
    Bradley
  15. #892
    I'm expecting a few pictures from Jeff soon. He says to him, they all look the same!
  16. #893
    Kennebunkport, ME
    But him some more rum and he’ll get down faster.
    Kyle
  17. #894
    Quote Originally Posted by KDubU View Post
    That might work on Miller, but may just put Kleiner to sleep.
  18. #895
    I got some pictures today from Jeff. Body is 95% done with fitting and shaping. A couple days to cure, then the body will come off and the Slick Sand will go on. Getting closer to seeing some color!
  19. Likes GoDadGo, Yama-Bro, SSNK4US, PeteMeindl liked this post
  20. #896
    Jealous, You Bet I Am!
  21. #897
    Tampa, FL
    Papa,
    Saw your car today in person... coming along nicely
  22. #898
    Quote Originally Posted by Racee75 View Post
    Papa,
    Thanks! It's pretty exciting to see the progress and knowing it's that much closer to being finished.
    TMartinLVNV's Avatar
    Jun 2019
    Las Vegas, NV
    Dave, it is great seeing your car nearly finished. It provides some inspiration of what I hope mine will be one day. Your thread is one of the guides I have printed out to amend the FFR manual. I just got the body off last night and am starting the build process. Upper and lower control arms, here I come!
  24. #900
    Quote Originally Posted by TMartinLVNV View Post
    Thanks, and enjoy the ride! The build experience was awesome.
  25. #901
    Greeneville, TN
    That is really exciting to see Dave.... It looks so plane with the shinny knocked off... LOL I'm getting excited because I know that mine will be there in the near future as well...
  26. #902
    Bakersfield, CA
    And somebody cut a hole in your hood??!!?!??
    I’m so jealous! You gotta be just chomping at the bit.
    Any rough ETA? Not that you want to rush a master artist....
    Kurt
    Build thread
  27. #903
    Kurt
    Kurt,
    No ETA and I'm not even asking. Jeff has been giving me periodic updates and we've chatted a few times since the car has been in his shop. I'm anxious to see it finished, but not to a point that I want Jeff to feel pressured to finish it. I already feel bad that Jeff has had to deal with a couple of other issues with the car. It fouled three plugs again. I'm not sure what is causing that, but will work on it once I get the car back. In the mean time, it means Jeff has to swap out the fouled plugs to get it to run right. Also, he's addressing my front end alignment. Where I had eyeballed it, the front wheels were too far forward and he's going to adjust it to closer to where it should be for me. When I get it back, I'll have the shop that the local Cobra club recommends dial it in. It will be done when it's done and I'm confident it will be everything I hoped it would be. Oh, and I'm glad I didn't have to cut the hole in the hood!
  28. Likes Yama-Bro liked this post
  29. #904
    Excited for you Dave! I’ll have a week of vacation coming up where I’m going to have most everything buttoned up and ready to roll and get to where you are in the journey. I’m sure yours is going to look great!
  30. Thanks Papa thanked for this post
  31. #905
    Feb 2018
    Frisco, TX
    When I mounted my hood I could not get it to sit flush with the body along the front edge, especially in the center - the ends were not too bad. Is it a common problem? Is this why there is so much body filler on the nose of the body to correct this?
  32. #906
    ...Is this why there is so much body filler on the nose of the body to correct this?
    No, the large area of filler on the nose is because of a tremendous amount of mold misalignment.
    Jeff is being nice. He told me that I win the prize for the worst MK4 body he's gotten his hands on. I can't imagine what the car would have turned out like had I sent it to a shop that wasn't familiar with these cars.
  34. Likes Aircontroller liked this post
  35. #908
    Kearney Nebraska
    This is the exact reason why I'm leaning towards making the trip to Indiana with mine as well. There are a lot of competent painters in my area, but not many that have experience doing the body work to an FFR.
    Serial #9158
  36. Likes Papa liked this post
  37. #909
    Talked with Jeff and my car should be in Slick Sand Monday or Tuesday!
  38. Likes PeteMeindl liked this post
  39. #910
    Mar 2017
    Nice!!!!!!
    Build#1: MKIV Roadster #9320
  40. #911
    Quote Originally Posted by stevant View Post
    Nice!!!!!!
    Thanks, Steve. It's getting closer to getting some color.
    Thats a great feeling, isnt it...
  42. #913
    That it is, Boyd. I've been following your thread and loving the theme you've got going.
  43. Thanks Boydster thanked for this post
  44. #914
    Thank you very much. Looking forward to seeing some color on yours.
  45. #915
    Well, I managed to find a way to spend a little more on my build even though the car is 1,100 miles away. Ever since I ordered my kit, I've wondered why I didn't buy the 18" Halibrands. The 17" wheels look great, but the 18" have that little extra cool factor with that fat rear lip. So, I ordered a set today. I'm looking at the BFGoodrich g-Force Rival S 1.5 Tires in a 245/40-18 front and 315/30-18 rear. Are there any better matching options that you guys are happy with? Once I get the car back and get the new shoes on, I'll be offering my 17" with Nitto 555 G2 tires for sale.
  46. #916
    Greeneville, TN
    Dave,
    I've been very happy so far with these... I have 8000 miles on them and really like the grip and the wear. Of course I'm not doing any kind of autocross to speak of and I do drive in the rain quite a lot. They really seem to have nice wet grip. Michelin Pilot Sport PS2 315/30R18 98 Y
  47. Thanks Papa thanked for this post
  48. #917
    Dave,
    I had these on another car and liked them. What size are you running on the front?
  49. #918
    Greeneville, TN
    Michelin PILOT SPORT PS2 - 255/35ZR18/XL 94Y
  50. Thanks Papa thanked for this post
  51. #919
    Thanks, Carl. I've got a set ready to order from my local Discount Tire.
    Jul 2019
    I caved in on the 18' wheels during my order. That extra inch isn't cheap and I was attempting to be "frugal" to appease DW, but that lip is too sweet to pass up. Thankfully she approved once seeing the two side by side.
  53. Likes Papa liked this post
